Old 12-28-2010, 10:27 AM
Tyler14's Avatar
Member #10311
Thumbs down 2001 TB250 problems
I picked this quad up off of a very reliable buddy of mine knowing it needed some work to get it running. The entire topend is new at .030 over, otherwise its bone stock. Got the whole thing assembled and ready to test run/break in and now I'm having some problems...
The bike will start and run on full choke and then continue to run on half choke. There is absolutely no idle capability when off choke. Also, the engine seems to lag quite a bit when the throttle is opened. I also get some exhaust detonation that pops the headpipe apart at the joint between the 2 sections, usually after a strong rev when the bike is idling back down. This includes a proper amount of warm up time. The carb has been completely dis-assembled, cleaned and checked. All intake boots are crack free and no air leaks are detected. As far as I know, the jets are stock. Compression is good and I have installed an oil injection block off kit with single pull throttle cable and I am running 40:1 premix. I have adjusted the ETC gap to spec and even tested the bike with it bypassed. The carb slide has complete closure and full range of motion in the carb.
I've tried just about everything I know to try on this thing and I'm coming up empty. I have many years of experience tuning 2-strokes, but all of my time has been with high performance rides with Keihin carbs. This Mikuni is becoming a pain in my d**k.
The only things I have yet to investigate but intend to are proper float level and maybe needle position or maybe even slightly bigger jetting.
I think I have provided as many details as I can remember so far...any ideas?
Thanx in advance...
Old 12-28-2010, 02:05 PM
Old 12-29-2010, 05:34 AM
3inthedirt's Avatar
Member #9037
I'm sorry but you still have an air leak on or at the carb somewhere. I would soak the entire carb, minus the orings and rubber parts, in Berryman's for a few days and blow it out with an air compressor if you have one.
Old 12-29-2010, 08:42 AM
Manaen's Avatar
Member #6699
if you are sure your carb is working properly (and I mean absolutely) it could be a poor case seal. If the case is leaking air it will not idle properly.
My bet is on the idle circuit of the carb (most common issue) . However since it is a fresh rebuild you could have some issues with an air leak somewhere in the case. The only way to tell is to pressure test the case. You may also want to perform a compression test. Keep in mind that on a two stroke the compression is only part of the story you still need a good case seal to create proper flow through the intake ports.
Before doing all that double check everything on the carb, reset the float level, clean/clear idle circuit, make sure your jets are the stock numbers and clean, adjust the needle and idle mixture back to stock. Then go from there.
2001 polaris trailblazer 250 compression
2001 polaris trailblazer 250 engine low compression
2001polaris trailblazer carburetor repair
250 trail blazer tune up
250 trailblazer wont stay running
fuel leak polaris trailblazer
how to adjust a carburetor on a polaris trailblazer 250
how to adjust the carburetor on a 2001 polaris trail blazer 250cc
how to adjust throttle on polaris trailblazer 250
how to bypass oil injector on a polaris trailblazer
how to clean a idle circuit on a polaris carb
how to repair gas leak on 2001 polaris trailblazer
how to replace throttle cable 2000 polaris trailblazer
polaris 250 compression test
polaris 250 trailblazer only runs with choke half way
polaris trail blazer 250 tune up specs
polaris trailblazer 250 throttle bypass
polaris trailblazer stock compression
trailblazer 250 where is the idle circuit
why does my polaris trailblazer 250 quad run only at half throttle
2001 sportsman 500 HO only 3wd john bouy Polaris Sportsman 3 12-28-2010 01:28 PM
2001 awd?? MudBuddy ATV Repair and Maintenance 2 12-12-2010 11:03 AM
2001 polaris trailblazer tranny problems puppet ATV New Members 6 04-25-2010 07:31 AM
2001 Sportsman 500 Problems Help!! russellmxz Polaris Sportsman 1 03-14-2010 07:00 AM
2001 Sportsman 500 H0 key starting problems bigwavedave ATV Repair and Maintenance 2 10-18-2009 04:50 PM
