Old 12-30-2010, 11:18 AM
paraord's Avatar
Member #10460
Exclamation Trail Boss 4x4 OEM Rear tires question
As i have yet to get any response in the tires section, can anyone verify what the tire size for the rear is supposed to be on an 87 trail boss 250 4x4? i have seen 22x11x10 and 24x11x10 and was wondering if anyone can confirm the correct size?
1987 Trail Boss 4x4 250
Old 12-30-2010, 03:16 PM
4getful2's Avatar
Member #1234
correct size 24 x 11 x 10 rear
Old 12-30-2010, 03:47 PM
paraord's Avatar
Member #10460
thank you. any idea how harmful it would be if i put 25's pn the rear? finding 24 used is pretty difficult and ill be honest i really dont want to put more into the tires that i did the whole thing haha.
Old 01-06-2011, 12:31 PM
paraord's Avatar
Member #10460
any feedback on this?
Old 01-06-2011, 01:14 PM
cwlongshot's Avatar
A 25" tire shouldn't be an issue. BUT depending on the condition of your clutches and belt. The larger tires will put more of a toll on your belt. But generally speaking, 1" larger causes no problems.
BTW the 22x11x10 is for the 2WD Trail Boss/Blaser.
1987 polaris 250 tire size
1987 polaris trail boss 250 4x4 tire size
1987 polaris trail boss tire size
1987 polaris trailboss tire size
1987 trail boss 250 tire size
1987 trail boss tire size
2000 plorais trail boss is it 4x4
92 polaris 250 trail boss 4x4 tires
air pressure in a 87 trail boss 250
polaris trail boss 2001 tire size
polaris trailboss tire ratio
rear tire size on polaris trail boss 2001
tire pressure for polaris trail boss at
tire size 1986 polaris trail boss 250
what are polaris trail boss oem tired
what if i put bigger tires on front of polaris trailboss
what should tire pressure be polaris trailboss 250
what size tires are on a 1987 polaris trail boss
what tire pressure polaris 325 trailboss
87 Trail Boss 250 tires???? paraord ATV Wheels & Tires 4 12-29-2010 04:59 PM
trail boss question???? 2strokertrlboss ATV Repair and Maintenance 2 12-18-2010 12:48 PM
Rear brakes on 2001 Trail Boss neilm2534 ATV Brakes & Suspension 3 12-04-2010 08:07 AM
Trail Boss 330 heavier rear shock? Orion6 ATV Brakes & Suspension 0 04-12-2010 06:00 AM
Question on Trail Boss lbean74 ATV Repair and Maintenance 6 12-12-2009 07:54 AM
