Old 01-01-2011, 07:20 AM
Timbo's Avatar
Member #10634
VIN question and reverse isssue.
Hey guys, I have a 350 Trail Blazer and can not find any info on the VIN # W938139. That is the # on the front upright behind the tire, it is on a metal tag. There is also the # 7073825 to the right of the first number, if that helps. I need to know the year so I can buy some parts.
Also when I put it into reverse it sometimes dies, any ideas? If I quickly put it into a different gear it will stay running. This problem does not always happen.
Thanks for your help.
Old 01-01-2011, 07:45 AM
benm's Avatar
Member #3578
Im pretty sure the 93 after the W is the year.
Old 01-01-2011, 07:54 AM
Timbo's Avatar
Member #10634
Thanks, that helps.
Old 01-01-2011, 08:28 AM
Neither of those two numbers are valid vin#s, but the W93 is a model number, and from that, I can confirm that it is a 1993 350L 4X4. I cant remember, but does it have the reverse override on the handlebars on this model?
Old 01-01-2011, 08:41 AM
Timbo's Avatar
Member #10634
Yes it has a override.
I just went and looked and found another metal plate welded to the frame by the sticker(sorry the vin I provided was on a sticker), it has *2112763* stamped into it.
Do you know where the VIN should be?
ALso could you tell me if it is a two or four stroke?
Old 01-01-2011, 08:47 AM
That number is the vin!
Production Date 07/07/1993
Purchase Date 08/17/1993
Registration Date 11/10/1993
Warranty Expiration Date 02/17/1994
Model Year 1993 TRAIL BOSS 4X4 350L
Engine Number : 9322396
And all 350's were two strokes, especially in that day
Old 01-01-2011, 08:53 AM
Timbo's Avatar
Member #10634
Thanks a bunch.
Any ideas about the reverse issue?
01 polaris trailblazer in reverse it dies
1993 polaris 350 4x4 vin numbers
1993 polaris reverse overide module location
1993 polaris sportsman 400 awd problems
1993 polaris vin location
1994 polaris 400 4x4 stalls when put in reverse
1994 polaris stalls when put in 4x4
polaris 300 4x4 vin
polaris 300 where to find vin #
polaris 350l, stalls in reverse
polaris 93 vin:w938139
polaris model w93/527
polaris w938139
polaris w938139 reverse problems
polarius model w93/527
vin on 1993 polaris 350
were is the serial number on a 350 polaris
where could i find the vin number on a 94 polaris atv 4x4
where do you find the serial number of a 1993 w93 polaris 4wheeler
where is the vin on a 93 sportsman
No 4wd in reverse Mike109 Polaris Sportsman 2 02-04-2012 12:03 AM
Reverse lights anyone???? ratlnram Polaris Sportsman 10 12-15-2010 04:24 AM
300 4x4 comes out of reverse speedhammer ATV Repair and Maintenance 3 08-13-2010 05:46 AM
no 4wd in reverse Austin61 Polaris Sportsman 9 01-16-2010 06:47 AM
polaris 500 no 4x4 in reverse cecdog ATV Repair and Maintenance 4 07-13-2009 12:26 PM
