Old 01-02-2011, 07:16 AM
Timbo's Avatar
Member #10634
Question about "Y" throttle cable
On my 93 350 4X4 it has a "Y" throttle cable, on the Y, one end goes to the carb. The other end goes down to the front of the crankcase, what does this end connect to and what is its purpose?
Old 01-02-2011, 07:44 AM
waynev's Avatar
Member #6512
if it is 2 stroke it goes down to the oil injection pump
2010 Sportsman 850 XP EPS Stealth Black
Glacier II Plow System
3500 lb Polaris Winch w/ synthetic rope,Rubber Down Customs: Custom "GOT MUD" Aluminum Fairlead
2010 Sportsman 550 XP EPS Crimson Red, Rear Seat
Old 01-02-2011, 07:53 AM
Timbo's Avatar
Member #10634
Thanks waynev!
Old 01-02-2011, 08:56 AM
waynev's Avatar
Member #6512
no problem
Old 01-02-2011, 12:19 PM
waynev is correct. the 350L is a 2 stroke, so one end does go to the carb, the other end goes to the oil injection.
Old 01-02-2011, 12:25 PM
waynev's Avatar
Member #6512
yup we have a trail boss 350L at home it's a 1991 runs perfect. did alot of work to it but it likes to eat clutch covers lol the motor mounts were broke before.
Old 01-02-2011, 12:34 PM
Timbo's Avatar
Member #10634
Mine is pretty beat, need struts/shock, starter solenoid, a rebuild, but it starts on the first pull and plows the snow good.
I was going to replace the cable but its $104! Guess I'll just lube it and hopes it hold out.
Old 01-19-2011, 09:59 AM
shane_zuk's Avatar
Member #8650
Get an oil injection block off kit, pre-mix, and get a cheaper single throttle cable. The injection block off kits with cable are around $60. Ritter Cycyle Racing has them, that is the kit I have on mine.
Old 01-19-2011, 11:15 AM
Timbo's Avatar
Member #10634
Thanks Shane, I'll look into it.
2000 polaris trail blazer throttle cable
2003 polaris trail blazer throttle cable
350 polaris atv throttle cable
93 polaris 350 throttle cable adjust
atv y throotle cable
how do i replace the thrttle cable on a polaris 350l
how to change a throttle cable on a polaris 325 trail boss
how to change throttle cable on polaris trailblazer
how to install polaris throttle cable
how to install throttle cable polaris 350
how to install trottle cable polaris atv
how to remove the oil pump cable polars atv
how to replace throttle cable 2000 polaris trailblazer
polaris trail blazer single throttle cable
polaris trailblazer throttle cable install
polaris trailboss 350l oil injection cable
polaris trailboss 350l y throttle cable
replacing a throttle cable on an polaris
throttle cable setting for polaris 400 trailblazer
2006 Sportsman 700 EFI "dies above idle" NEED HELP ASAP FOR WEEKEND RIDE xlwater Polaris Sportsman 4 05-18-2011 03:30 AM
I'm thinking "Western States" with Alaska and Hawaii and the rest... Bruce! Western States 8 02-02-2011 04:50 AM
"Clicking" sound coming from front end when turning (05 Sportsman 400 4x4) NickS ATV Repair and Maintenance 8 01-03-2011 05:48 PM
Polaris 700 Twin EFI... "Wait" and "End" Error? TechieSooner Polaris Sportsman 3 11-26-2010 06:20 PM
A "Mark Forums Read" button (link) working. scottdeet Site Issues & Suggestions 4 09-17-2010 06:51 PM
