01-08-2011, 10:20 AM
Member #10460
trail boss 250 10mph max???
Ok i got my "pile" running and driving. but for some reason it only wants to do about 10 or so??? I have to assume this thing can do better than that. Anyone have any ideas about this?
Maybe some electrical thing? I have no idea
Its an 87 Trailboss 4x4.
1987 Trail Boss 4x4 250
01-08-2011, 10:28 AM
Member #8052
hmmm... gonna need some more info to go on than that i'm afraid. does it bog down when it gets to 10mph or does it sound like it's at max RPM? what's your sparkplug look like?
01-08-2011, 10:31 AM
Member #10460
it kinda bogs down from a little past idle and it seems maxs out at 10, almost like it flooding but i have good floats, and the carb is as clean as its gonna get. Spark plug is giving great spark when i ground it and pull it over. looks wet, not new but not toasted either. it doesnt seem like its getting to max rpm either
01-08-2011, 10:44 AM
Member #10460
on a possibly related note, that idle adjustment screw out the right side( as if sitting on the wheeler) what is the recommended setting?
01-08-2011, 02:15 PM
Member #10460
lets add hard starting to the mix. anyone?
01-08-2011, 03:01 PM
Member #1234
My book doesn't go back that far but it's usually 1 1/2 turns out ,realize that this is the starting point. Get it warmed up then adjust to the smoothest ,highest idle that you can achieve ,then back in a quarter turn. Do this with the air filter and housing installed, by the way is the air filter clean?
check fuel flow coming from tank
run a compression check (cold)
if the motor is in good shape mechanically,will rev up good in neutral, then you may want to look at the rear clutch
10 mph atv, 10mph atv, 1987 polaris trail boss bogs when pulling out, 1987 trail boss compression numbers, 1987 trailboss bogs down, 250s-10 atv, 4 wheel trails, rochester ny, 91 polaris 4x4 250cc how to put in 4 wheel drive, atv 10 mph, atv 10mph, bog boss 250, how do you pull the engine out of a 1987 trail boss, how to diable 4 whell drive on 91 polairs trail boss, polaris atv rochester ny, polaris trail boss 4x4 4 wheeler compression, price on polaris trail boss in rochester ny, problem with the four wheel drive on my 91 polaris 250 trail boss, trail boss 250 has no spark, trail boss 250 rpm, trailboss 250 rpm
