Old 01-25-2011, 06:35 PM
mtc's Avatar
mtc mtc is offline
Member #11423
Carb Location and VIN Check
Newbie here. 1st Post. Bought a 2001 TB 250 2x4 (as far as I know) this weekend. Runs pretty good. Would like to possibly tweek carb settings as it won't hold idle after it warms up. Idles fine cold. Any ideas? Anyway, how do I access the carb? Also, blueline15, can you run the VIN for me? It's 4XABA25C212477723. TIA.
Old 01-25-2011, 07:01 PM
Checked the VIN, something isnt right, it came back invalid. Does it idle fine cold without the choke on, or is that with the choke on?
Old 01-25-2011, 07:31 PM
Seattle (July 9-11)
Old 01-25-2011, 07:36 PM
mtc's Avatar
mtc mtc is offline
Member #11423
I haven't had to touch the choke even at low ambient temperatures. Pretty much starts second or third pull (battery dead. no elec start) and idles (a little rough at first). After riding for 10-15 minutes or so, I need to maintain throttle at rest to keep from stalling. BTW, I fat-fingered the VIN. It's 4XABA25C212477773. Thanks. Great forum.
Old 01-25-2011, 08:28 PM
cookies's Avatar
Member #8052
there should be a brass flathead type screw on the outside of the carb to adjust pilot jet. you may want to pull the whole carb and give it a good scrubbing though, im betting it'll make the machine run much better overall.
Old 01-26-2011, 07:40 AM
hey mtc, the vin still is not coming up as valid.
Old 01-26-2011, 10:27 AM
mtc's Avatar
mtc mtc is offline
Member #11423
Is this VIN at least in the correct length/format? I got ir right off of the frame. It's etched, or stamped, right behind the LF wheel.
2001 polaris atv vin
2008 polaris atv vin location
atv vin check
atv vin check --filetype:ps -filetype:dwf -filetype:kml -filetype:kmz -filetype:xls -filetype:ppt -filetype:doc -filetyp
carburetor access on polaris atv
check atv vin --filetype:ps -filetype:dwf -filetype:kml -filetype:kmz -filetype:xls -filetype:ppt -filetype:doc -filetyp
check polaris vin
how to check an atv carburetor
polaris 330 carburetor access
polaris atv carburetor location
polaris atv vin check
polaris atv vin search
polaris carburetor access
polaris vin check
polaris vin search
vin check trail
what are the serial numbers for 2001 250 polaras trail blazers?
where is the carburetor
where is the vin # on a 01 polaris atv
Check this out! 2001sportsman400 ATV Repair and Maintenance 1 01-13-2011 11:26 AM
Check these out! loadbreak ATV Wheels & Tires 5 12-12-2010 09:46 AM
Carb Main Jet E clip location Nandy Polaris Sportsman 1 09-06-2010 07:52 AM
vin # location tony0783 Polaris Sportsman 2 01-02-2010 11:10 PM
Carb settings needed and Carb issues NolenGerke Polaris Trail Blazer 3 08-26-2009 03:30 PM
