09-14-2009, 06:31 PM
Member #1409
2004 TrailBlazer Rear Brake Issue
New to the forum and wondered if anyone has had trouble with the real brake cylinder on the trailblazer. I just bought this bike for my wife and it is great shape except for the issue with the rear brake. I know that the front lever operates both front and rear calipers but the foot lever on the right side is pretty much useless at this point. Any help would be greatly appreciated.
09-14-2009, 06:57 PM
Member #1180
Same Issue
I've got the same issue with a 2000 Xplorer 250. Might as well not even have a rear brake pedal. Rear disk works fine with the handlebar lever, but the foot pedal won't even keep the rear wheels from turning. Looking for a solution also...
09-14-2009, 07:01 PM
Member #1409
cdakers - I have talked to a few people that said to replace the rear master cylinder and that should take care of it. They are 120 dollars so I would like to know this is going to fix it before I spend the money.
09-14-2009, 07:25 PM
Member #1180
My thoughts too
That was my thought too. The piston on the rear master cylinder has to travel almost an inch before there is any noticeable drag on the rear wheels. Just about the time you run out of travel on the pedal it seems to start putting pressure on the caliper. I really don't want to spend the money on it either, so maybe I'll take it apart and have a look.
09-14-2009, 07:29 PM
Member #1180
Forgot to add
I forgot to add I've already replaced the fluid and bled all of the old fluid out of the system. Didn't help.
09-14-2009, 07:47 PM
Member #1409
Thanks for the info. I may call the local Polaris dealer tomorrow and see if they can offer any information as to what the problem might be. I will post any news I get.
09-27-2009, 09:10 PM
Member #1454
Replacing the rubber line w/steel braided @ the rear caliper would help a bit---Proflow
09-28-2009, 10:24 AM
Member #552
Keep in mind the foot pedal brake is made as an emergency brake only. If for some reason the hand brake fails this is your back up. It was not designed to use all the time, taking a good look at the teaspoon sized master cylinder should be a good indicator.
11-02-2009, 04:37 PM
Member #1856
the foot brake is to be used any time mostly for slowing the machine when going down steep hills although the hand brake does apply pressure to both front and rear brakes at around a 70 30 f r ratio
04-26-2010, 05:28 PM
Member #635
I'm having the exact same problem. I bought this 4 wheeler for my son and it is super nice...except the pedal does nothing. I changed the pads and filled and bled the rear caliper. Still no rear brakes. Is the master the answer? Anywhere have them cheap or is it a dealer item?
2005 Predator 500, Holeshot HD's, Pure Polaris slip on, 1" bar riser. (Mine)
2005 Sportsman 700 EFI, EPI clutch kit, Aaen megaphone muffler, 27" Highlifter Outlaws. (Mine)
2002 Sportsman 500 H.O. Remington Edition, 26" PXT's. (Wifes)
2001 Trailblazer 250 (Son #1)
2007 Phoenix 200 (Son #2)
2003 Predator 50 (Son #3)
04 trailblazer brakes dont, 2002 polaris 250 trailblazer brake system, 2002 polaris trailblazer 250 rear brake caliper, 2002 polaris trailblazer back brake problems, 2004 trailblazer rear brake replacement, 2005 polaris phoenix 200 master cylinder, 2005 trailblazer problem with brakes, 250 trailblazer master cylinder, change brakes 04 polaris trailblazer, does the 2001 polaris trailblazer 250 rear brake problems, how to bleed back brake on polaris trail blazer 250, how to bleed rear brakes on 2002 trailblazer, how to bleed the back brakes of a polaris trailblaizer, how to fix a brake caliper on a polaria trailblazer atv, how to get back brakes on a polaris trail blazer to work?, how to take brake pads of of a polaris trail blazer front, polaris trailblazer lost the brakes, rear brake caliper 2001 polaris trailblazer, what brake caliper will work on the rear of a 2004 polaris trailblazer 250, where is the parking brake located on 2004 polaris trailblazer 250
