Old 02-22-2011, 04:54 PM
jdereu's Avatar
Member #5980
A-Arm Removal
What the hell am i missing?!
Trying to take the a-arm off of my 2000 ttrailblazer. Got the crown nut off by the tire, and the forward bolt holding the a-arm to the frame. Go to take the rear off and it just spins. What am i missing.
Old 02-22-2011, 05:22 PM
You are talking about bolts #25?
Old 02-22-2011, 05:26 PM
jdereu's Avatar
Member #5980
yes sir i am
Old 02-22-2011, 05:28 PM
scottdeet's Avatar
Member #7044
I just replaced the Left A-Arm on a `98 Scrambler 400.
There's a shaft that goes through the A-Arm and spins.
If possible, since you got the front bolt out, try removing parts (A) they should slide out if you can lower it enough.
Then hold the end of the shaft (B) with vise grips.
Did you compress the coil spring before taking the ball joint nut off?
This makes it easier to remove the part of the A-Arm that's attached to the ball joint bolt.
I used a gear puller to get that part of the A-Arm off the ball joint bolt instead of removing the 2 bolts
that hold the ball joint socket on and removing everything.
Take care,
Scott Deeter
Old 02-22-2011, 05:31 PM
jdereu's Avatar
Member #5980
If that doesnt work any other ideas? And i got the ball joint end off easy just a little tap with the dead blow
Old 02-22-2011, 05:51 PM
scottdeet's Avatar
Member #7044
Then try sliding the A-Arm right off the shaft with exposing it completely.
Then grab it with vise grips holding it still and removing the rear bolt.
Lowering the front part of the A-Arm should be possible, but it "may"
bend the rear bracket a little. If this happens, just bend (hammer) the
back bracket back to where it needs to be and put it back together.
Are you replacing the A-Arm?
I replaced this A-Arm from the `98 Scrambler where the front bracket
was actually broke and I had to bend it back & weld it.
Take care,
Scott Deeter
Old 02-22-2011, 06:04 PM
jdereu's Avatar
Member #5980
i got it. thanks guys
shit anyone else think that was a dumb design
Old 02-26-2011, 03:32 PM
jdereu's Avatar
Member #5980
Figures now i cant get the ball joint off the other side.
HELP yall
Old 02-26-2011, 04:37 PM
scottdeet's Avatar
Member #7044
HELP yall
Here's some instructions thay may help.
I'm trying to get the pages to show up better.
To view larger, click on pic, then Double click, then click
again when the pic is in the seperate window.
Take care,
Scott Deeter
Old 03-20-2011, 06:27 AM
st.marys's Avatar
Member #13104
Bolt 17, and nut 17 are driving me nuts! My front tire is wobbling around on a 2000 scrambler, have the tire removed, quad is all jacked up and everything. I'm trying to start tearing the whole assembly to find the problem, but can't get that nut off. The bold just spins. I tried vise gripping it at the end, no luck. I also looked at another way to get at it, but I'd have to start with the entire suspension, top down to get at it. Uggggh! Any thoughts for a newbie?
a-arm removal on a polaris trailblazer
atv a arm removal
how do you take on a arm on a polaris atv
how to get a arm of polaris trail blazer
how to remove a polaris a-arm
how to remove atv a arm
how to remove atv a arms
how to remove front a-arms on atv
how to remove polaris a arm
how to remove polaris scrambler front a arm
polaris a arm removal
polaris a arm replacement
polaris atv a arm images
polaris atv a arm replacement
polaris lower a arm removal
polaris lower arm removal rear
removal of a arm on polaris
remove lower ball joint front strut polaris
remove polaris arm
remove polaris strut ball joint
550 Oil Filter Removal yooper49953 ATV Repair and Maintenance 11 06-21-2011 07:03 PM
Clutch removal peterbilt ATV Repair and Maintenance 4 02-23-2011 03:42 AM
magneto removal mustang 67 ATV Repair and Maintenance 1 02-20-2011 01:49 PM
Frt A-Arm Removal/700 Sportsman dkbowles ATV Repair and Maintenance 4 08-29-2010 10:08 AM
Pulley removal help bruce ATV Repair and Maintenance 5 01-26-2010 05:19 PM
