03-09-2011, 12:38 PM
Member #12790
need help to clean out fuel tank
I have a 2000 Polaris Trail Blazer and it had been sitting for a couple of years so the fuel in the tank got all gooey. I want to know if anyone knows what I can do to clean out the sludge. And if you have any other tips on what i need to do to try and get it running again. Thank you so much.
03-09-2011, 12:47 PM
WELCOME!!
First off, Remove the tank. Get yourself some plastic safe carb/throttle body cleaner and spray and let sit. Then flush with more spray and let sit.. you will get it!!
03-09-2011, 12:53 PM
Member #12763
Replacing the in-line filter might not be a bad idea as well
Proud member of the Vast Right Wing Conspiracy
03-09-2011, 12:55 PM
Member #12790
do you know of any house hold products I might be able to use to clean out the tank?
03-09-2011, 01:09 PM
Member #12763
Gasoli...oh wait.. Try a degreaser like simple green or purple power. When I was in the military I used simple green to clean everything, and I use pruple power now to clean jelly-like crude oil from wellheads. I think you will have the best results with carb cleaner though, that stuff eats through anything.
atv fuel tank cleaner, atv gas tank cleanin, atv gas tank cleaning, best gas tank cleaner atv, cleaning a atv gas tank, cleaning an atv gas tank, cleaning atv fuel tank, cleaning atv gas tank, cleaning out a atv gas tank, cleaning out a plasic gas tank on a atv, how to clean a atv gas tank, how to clean a gas tank on a atv, how to clean an atv gas tank, how to clean atv gas tank, how to clean atv plastic fuel tank, how to clean gas tank atv, how to clean out a gas tank on an atv, how to clean out an atv gas tank, how to flush atv gas tank, how to get old fuel out of atv
