Old 09-25-2009, 06:23 PM
indeepshitnow's Avatar
Member #1509
2001 Trail Blazer loses juice...?
Hey folks, new to the forums here. I just bought a 2001 250 Trail Blazer. Are there alternators on these things? I put the battery on charge for a while, it cranks, runs... Then I run it, and it dies down, no juice left... Any help is appreciated. I tried searching the topic with no results....
Old 09-25-2009, 06:44 PM
Old 09-26-2009, 04:47 AM
Member #1509
Thanks. I used to live in your area. Anyhow, I don't think it's the stator now that I have had a second look at this thing. The lights brighten up when I give it throttle. I think I may be dealing with a shyt battery.
Old 09-28-2009, 10:54 AM
Dirty Dawg Dale's Avatar
Member #552
Sounds like a bad voltage regulator. If the lights get brighter when revved up be careful as you could blow out all your lights.
website www.dirtydawgperformance.com
email mrgofast77@yahoo.com
contact 763-228-4345
Old 09-28-2009, 05:07 PM
Member #1509
So I would have to replace the stator? Or is the voltage regulator separate? I got a new battery, and so far so good, but yeah, the lights do brighten when I rev it...
Old 09-28-2009, 08:19 PM
Member #552
The lights will brighten a little if you rev it up. Usually if the voltage regulator was bad you would have all ready fried all your light bulbs.
Old 09-29-2009, 04:15 AM
Member #1509
Thanks... Quick question, do these things have a typical 'knock' when idling? I mean, it runs good but it could be an exhaust thing.
Old 10-01-2009, 09:38 AM
Member #552
It depends what you call a knock. Being any air cooled motor it will be noisy. This machines were always a little on the noisy side but some of the noise should go away once the motor is warmed up.
Old 10-01-2009, 11:22 AM
Member #1509
Thanks alot for your answers.
indeepshitnow
lights brighter when reved up atv
