Old 03-17-2011, 04:59 PM
bubba_v2008's Avatar
Member #13033
Exclamation 2006 polaris trailblazer 250 transmission problems
i have a 06 polaris trailblazer 250 2stroke when i first got it every now and then the shifter would pop out of drive and into neutral but never in reverse.but now when i put it in drive and give it gas it moves about 2 inches then pops into neutral but i can put it in reverse and drive it all day without it popping out i dont understand ive read on a few websites on google that it could be the shift fork how hard is it to get to the shift fork.and replace it.ive tried adjusting the linkage but no better no worse any ideas would be much apprieated thanks bubba
Old 03-17-2011, 06:23 PM
Old 03-17-2011, 06:38 PM
Member #13033
thanks man i appreiate it.
Old 03-18-2011, 01:40 PM
shane-o's Avatar
Member #4665
ive heard of people taking the trans apart to get the shift fork defintly would have to coem out and split apart which isnt a big deal on a polaris becouse its seperate from the engine ! ive also seen a guy grind down the edges of the gear the fork locks into they get rounded edges from ramming them into gear while idleing to high or having bad clutches and usually causes what your describing
Old 03-18-2011, 07:47 PM
Member #13033
thanks for the advice man ill give that a shot i was gonna work on it today but got caught up installing some clearance lights on my one ton diesel.yeah i let some people ride it bfore and when it would pop out of gear they would imediatly try and put it back in before the engine would idel down so i figured that would most likley be the problem thanks for the help!!!!
06 trailblazer 250
2006 polaris tail blazer
2006 trailblazer 250
polaris 2006 trailblazer 250
polaris 250 trailblazer
polaris 250 trailblazer transmission
polaris trailblazer 250 no reverse
polaris trailblazer 250 problems
polaris trailblazer 250 reverse
polaris trailblazer 250 shift fork
polaris trailblazer 250 transmission water
polaris trailblazer shifter fork
polaris trailblazer transmission issues
polaris trailblazer transmission problems
polaris transmission problems
transmission problems hasbeen10 ATV Repair and Maintenance 10 02-02-2012 09:40 PM
00 trailblazer transmission noise petey882 ATV Repair and Maintenance 4 12-24-2010 04:50 AM
00 trailblazer transmission clunking petey882 Polaris Trail Blazer 1 12-19-2010 07:30 PM
Transmission Problems trailboss4x4 ATV Repair and Maintenance 2 08-22-2010 06:35 PM
2001 polaris trailblazer tranny problems puppet ATV New Members 6 04-25-2010 07:31 AM
