Old 03-26-2011, 03:44 PM
rex's Avatar
rex rex is offline
Member #13347
2005 Trail Blazer
My 250 Trail Blazer runs fine until it reaches operating temperature and then shuts off. It will not start back up until it cools. Can anyone help?
Old 03-26-2011, 05:25 PM
dwhst9's Avatar
Member #11907
Send a message via AIM to dwhst9 Send a message via Yahoo to dwhst9
Try loosening your gas cap and go for a ride. If it doesnt shut off, your tank vent is blocked.
Old 03-26-2011, 08:11 PM
rex's Avatar
rex rex is offline
Member #13347
2005 Trail Blazer
I will try that. Thank you.
Old 03-29-2011, 04:46 PM
3inthedirt's Avatar
Member #9037
If the cap does not solve it, it could be a bad coil. It would be hard to detect with an ohm meter unless hot and even then it is difficult.
Old 04-12-2011, 02:34 PM
shane-o's Avatar
Member #4665
id check for spark when it gets hot ...also check the compression possibly getting low mine did almost that it would get real lazy when it was hot and if i shut it off id be there for about 45 minutes ended up replacing the piston and rings which isnt a big deal at all on these little 250 2 strokes !
Old 06-21-2011, 06:14 PM
mingojr's Avatar
Member #15780
If you haven't changed the spark plug lately try a new plug made for the 250 and make sure it is gapped right. Just a thought. Cheap fix hopefully
05 polaris trailblazer 250 spark plug gap
05 trailblazer cutts off and wont restart hot
2005 polaris 250 not starting
2005 polaris trail blazer starter clicks
2005 polaris trailblazer 250 runs till warm then wont start
2005 scrambler 250
2005tral blazera
99 polaris trailblazer spark gap
gasoline cap for trail blazer polaris 2005
how do you shift a 2005 polaris trail blazer
how to change spark plug 2005 polaris 250
my 05 polaris trailblazer 250 wont start
polaris 250 runs until hot and thendies
polaris 250 trailblazer shuts off when hot
polaris gets hot and will not run
polaris ranger wont start til cools off
polaris trailblazer 250 gas cap length
polaris trailblazer starter 2005
remove starter 2005 polaris trailblazer 250
spark lug gap for 2005 polaris 250
Trail blazer help dave37r Polaris Trail Blazer 3 01-16-2011 05:50 AM
'99 Trail Blazer help Drbrodent ATV Repair and Maintenance 1 10-31-2010 07:48 PM
2001 250 Trail Blazer jmtbraun ATV Repair and Maintenance 5 08-04-2010 07:13 AM
trail blazer help goldnut ATV New Members 3 10-20-2009 03:28 PM
Please help guyz, 92 trail blazer Mrt71 Polaris Trail Blazer 4 08-23-2009 03:33 PM
