03-27-2011, 08:09 AM
Member #13374
2003 TRAIL BLAZER output shaft HELP!
I'm having issues with a part number that was replaced on 2003 250cc Trail Blazer the part number I keep ordering is "3234224 output shaft" apparently replaced part number "3233689" I attached a pic of my problem. Between the sprocket output gear and the other gear, the shaft spacing is different? HELP ANYONE? MY Vin # is 4xaba25c832874858. The shaft cleanly broke off where the small chain sprocket attaches. IMAG0095.jpg
03-27-2011, 09:19 AM
03-29-2011, 12:27 PM
Member #13374
I stopped at a Polaris Dealer today and found out Polaris not only changed the part and number between the output shaft from 3233689 to 3234224 but the output gear shaft changed too from 3233688 to 3234266 so you cant buy one without the other. So I'm looking for a original shaft or a Gearcase for a 2003 250cc Trail Blazer the shaft also fits the following models 1999 sport,2000,2001,2002,2003,2004,2005 Trail Boss, Trail Blazer, or Scrambler. My shaft has sheared off where the small chain sprocket is attached " pic is above". Anyone out there with parts please help so I can ride.
04-11-2011, 02:00 PM
Member #13914
I just had my output shaft shear and am looking to do what you are doing. I have the new shaft on order. Was the swap easy? Any hints or tips?
04-12-2011, 05:16 PM
Member #13374
I just ordered the gear 3234266 in which comes with the shaft 3234224. So now i have two of these shafts ugh. Yea me thanks polaris for clearing that up. i have not installed it yet. I will post when complete
05-16-2011, 05:16 PM
Member #15118
I have the same exact issue.... I have a 96 Polaris 400L and the output shaft shear off right between the two sprokets. Does anyone know how difficult it is to do this job i found a replacment on ebay but looks like you have to crack the tranny open any tips?????
05-17-2011, 03:53 AM
Member #5749
very easy i've done many,,,,,,,just need snapring plyers& two jawed puller you can get at harbor freight,,,,,,,,,,,,,,
03 trailblazer steering shaft, 2003 polaris trailblazer output shaft, 2005 polaris scrambler sprocket shaft, how to remove polaris trailblazer transmission, how to remove the gear case from 2005 trail boss 330, how to remove transmission from 2004 polaris 330 trail boss, how to remove transmission on polaris atv, how to replace a quad sprocket shaft, how to take a transmission out of a 250 polaris trailblazer, out put shaft 2004 trail blazer 250 polaris, polaris trail blazer tranmission removal, polaris trail boss output shaft, polaris trail output shaft, polaris trailblazer 250 front sprocket shaft, polaris trailblazer 250 transmission interchange, polaris trailblazer output shaft, polaris trailblazer transmission removal, removing polaris trailblazer transmission, replace polaris trailblazer output shaft, trail boss shaft output
