Old 04-12-2011, 06:58 AM
sickofit's Avatar
Member #3429
89 Trail Boss 250 Float Height and Pilot Screw Turns
Hi guys...
Fixing up a 1989 Trail Boss for my farmer landlord...
You guys should see this thing...!!!...Its MINT..!!!!...I'll have to take a pic later,and show you guys...
He parked it years ago,as float was sticking,seeping gas out the overflow,and everytime he'd go to use it again,after filling it the last time,he'd get out in the fields,and it would run out of gas...LOL...
So got all the needed rebuild parts for the carb,but cant find the info for the float height,or the pilot screw turns out.Did a search,but all I could really find was to set the float parralel with the float gasket seat,but theres gotta be a service manual height to set it...anyone know it..??...and how many turns out on the pilot screw to start with..??
Its a 250 2 stroke...
Thanks...
Old 04-12-2011, 09:43 AM
jlewan88's Avatar
Member #9702
Air screw 1 1/2 turns out from closed.
Float height is parallel to carb. surface, holding carb. upside down.
1989 polaris 250 idle adjustment
250 trail boss adjusting carb screws
250 trail boss air adjuster setting
99' polaris 250 trailboss atv float adjustment
air fuel screw polaris trailblazer
air screw adjustment polaris 250 trailboss
carburetor adjustment for polaris trail boss
float height polaris trailblazer
how to adjust a carburetor on a 250 polaris trail boss
how to set carb on polaris 250 trail boss
how to set of the fuel on a 250 polaris trailblazer
ploaris trail boss 250 float adjustment
polaris 1988 trail boss carb floats
polaris 250 air screw
polaris 250 air screw settingn
polaris float adjustment
poraris trail blazee float level
sticking float on 250 trail boss atv
trail boss 250 air fuel screw setting
trailboss 25o carb adjustments
Trail Boss 330 fuel screw mthomas ATV Repair and Maintenance 2 02-23-2011 03:20 PM
2007 Trail Boss 330 float height mthomas ATV Repair and Maintenance 1 02-15-2011 01:38 PM
front shock height............. jroptop ATV Brakes & Suspension 5 01-25-2011 05:51 PM
Outlaw 90 Pilot Air Screw Adjustment Noozeyeguy ATV Performance Modifications 6 01-19-2011 12:17 AM
Looking for pilot Jet John Wayne ATV General Discussion 5 09-27-2010 09:39 AM
