Old 04-12-2011, 02:22 PM
motodad224's Avatar
Member #13957
rear brake caliper
I recently bought an '05 trailblazer for my wife and when I was playing in the yard on it the other day, I grabbed the brake lever a little hard and it blew out the rear caliper seal. My question is how big of a pain is it to rebuild the rear caliper, or am I better off just buying a new caliper? Thanks in advance for any insight you guys have.
Old 04-12-2011, 04:09 PM
Old 04-12-2011, 07:12 PM
7.62Addict's Avatar
Member #13356
Calipers are very easy to rebuild. You just need a little compressed air and a small set of picks to remove the square cut orings. I have done mine on my 01 500. Because its a stepped piston for the backup brakes, there are two orings. The only time you should need to replace the housing is if your piston bore is all oxidized from not changing the fluid or scratched up from improper handling during the break down. It would be really obvioius it its bad. You use a little compressed air to remove the piston, pull out the old orings and install the new ones. Use fresh brake fluid for lube and reassemble and bleed the brakes.
Old 04-13-2011, 05:18 AM
700ryder's Avatar
Member #12470
I too need to replace my caliper seal but when I was under the quad looking at it there seems to b some kind of star bit I will need..is that special.to a quad or is it just like an automotive bit
TONY.....
Old 04-13-2011, 05:28 AM
7.62Addict's Avatar
Member #13356
Nothing special, just standard fasteners. You should be able to get any of them at Sears. Torx bits are quite common.
Old 04-13-2011, 07:46 AM
motodad224's Avatar
Member #13957
Yeah this one has a backup brake as well, how do you remove the piston w/ compressed air? Do I just shoot it in the hole that the hose connects to?
Old 04-13-2011, 08:00 AM
7.62Addict's Avatar
Member #13356
you use a blow gun or air nozzle to push the piston out of the caliper piston bore. I would suggest removing the bleeder screw with a bleeder wrench or other six pt socket carefully as not to break it. Plug the brake hose hole with a finger or something and slowly apply air. Put your hand over the piston so it wont go flying across the room. It helps to drain out all the brake fluid first so you dont make a big mess. Brake fluid will remove paint and is just plain nasty stuff. I would suggest using Valvoline Synthetic brake fluid when you refill and bleed the system. Its just good stuff. Synthetic brake fluid is still hydroscopic so proper fluid flushes are still required to prevent heavy water contamination that can cause early brake line and caliper failure. DOT 3 and 4 brake fluid of all kinds absorbs moisture out of the air. Only DOT 5 which is not compatible is moisture proof.
2000 polaris 250 rear brake caliper
changinr rear brake seal on polaris trailblazer
how do you bleed the back brakes on a polarius four wheeler
how flush atv rear brake line
how to clean a brake caliper on an atv
how to put brakes on a atv
how to rebuild 08 polaris brake caliper?
how to rebuild a atv brake calipers polaris
how to rebuild a polaris brake caliper
polaris atv brake calipers
polaris atv rear brake caliper
polaris brake caliper rebuild
polaris ranger rear brake caliper
polaris scrambler rear caliper compatibility
polaris trailblazer rear brake caliper
rear brake calipoer leak fluid polaris sportsman
rebuild polaris brake caliper
rebuilding polaris rear brake caliper
rebuilding rear brake caliper on my polaris
Rear brake Caliper qquestion michaelbell85 Polaris Scrambler 3 04-27-2011 03:12 PM
SP 500 Rear Brake Caliper Polaris_Junkie ATV Brakes & Suspension 2 03-25-2011 03:18 PM
Rear Brake Caliper phillipnorton Polaris Predator 9 10-14-2010 06:18 PM
rear brake caliper bomberboat ATV Brakes & Suspension 5 07-27-2010 01:18 PM
Am I crazy, my 2010 xp only has one rear brake caliper? 03stage2 Polaris XP 14 06-05-2010 10:21 AM
