Old 05-09-2011, 04:48 PM
Oscar250's Avatar
Member #14167
1987 Trail Boss 250
I just got an 87 trail boss and i want to inspect the belt, what do i need to take off to get to the belt cover?
Old 05-09-2011, 05:32 PM
Old 05-24-2011, 08:44 AM
02renegade's Avatar
Member #14840
I will assume its like my '86...should be 4 bolts that hold the cover on which goes over both the primary and secondary clutch, that needs to come off, also there is a breather tube on top of the clutch cover that is bolted to the frame, that needs to come off also. I had to unbolt my rear fender a bit to get enough clearance for everything to move.
Old 05-25-2011, 01:55 PM
Oscar250's Avatar
Member #14167
Ok i removed the four bolts and three clips from the belt cover but it still wont come off. Is there another clip? and it looks like theres a gasket holding it on. What do i need to do to get it off?
Old 05-25-2011, 02:11 PM
Oscar250's Avatar
Member #14167
Ok i got the cover off. Whats the most miles i should put on it before i change the belt? Right now it has at the most 1000 miles on it.
Old 05-25-2011, 02:18 PM
02renegade's Avatar
Member #14840
Generally you check the width of the belt, I cant tell you what a new one measures but at a certain width you should change it, I usually look at the secondary clutch and look how far above the belt sits in the clutch. If the belt is sitting above or even with the outer edge of the clutch it should be fine. I would think you should not go through a belt in 1000 miles.
Old 05-25-2011, 02:44 PM
Oscar250's Avatar
Member #14167
Because of the age of the belt, should i change it anyway?
Old 05-26-2011, 12:39 PM
02renegade's Avatar
Member #14840
I would run it as long as it shows no sign of damage or dry rot.
1987 polaras clutch removel
1987 polaris 250 clutch rebuild
1987 polaris atv primary clutch cover
1987 polaris trail boss
1987 polaris trail boss 250
1987 polaris trail boss 250 for sale
1987 polaris trail boss weight
1987 polaris trailboss for sale
87 250 trailboss clutch removal
87 polaris trail boss 350 selling prices
87 trail boss for sale
for sale 1987 polaris trail boss 250
ploaris trail model 87
polaris trail boss 250 clutch turns continually
polaris trail boss for sale 250
polaris250trail boss clutch
trailboss 250 clutch removal
Trail Boss 250 1987 Question robertcwilkins ATV Repair and Maintenance 11 02-07-2012 11:35 AM
1987 trail boss I knew this going in 78dave ATV General Discussion 2 03-13-2011 11:36 AM
WTB Swing Arm for 1987 Trail Boss 250 4x4 laegion ATV Parts for Sale 2 10-22-2010 03:35 PM
1987 trail boss spikeman ATV Repair and Maintenance 14 04-09-2010 06:38 PM
1987 trail boss 4X4 brake issues.... xpsfisherman118 ATV Repair and Maintenance 2 03-20-2010 06:04 PM
