Old 05-13-2011, 08:12 AM
Cbystrack's Avatar
Member #15015
im the new guy asking a question that has been asked before im sure!
hey everyone, i have a 2001 polaris trailblazer 265 (bored) with a dg pipe and stock clutching... looking to see what input as to a clutch kit for the primary clutch..
I used to be a big snowmobiler and of course i rode nothing but polaris and what i can remember i always used a yellow spring with M10 weights in my clutch (primary) that set up made it grab around 7100rpm which is obv way to much for my fourwheeler..... dose anyone have a cheap dose of advice for me?
Thanks for the time- Chris
2001 Polaris trailblazer 265 2wd......its good enough for me!
1987 Camaro Iroc-Z 367 4 bolt main.....its slow
Old 05-13-2011, 09:15 AM
Old 05-13-2011, 06:24 PM
Cbystrack's Avatar
Member #15015
thanks bruce!
Old 05-17-2011, 04:05 AM
mechanike's Avatar
Member #5749
the stock spring on these have 0 starting engagement pressure (blue/green) i put a Brite Green EPI spring (18lbs) in my Scram500 cause i wanted to maintain the low-end torque that its famous for.now my 250 has a red EPI spring(27lbs?) which is two overstock which i think is perfect for mine(revs another grand off the line).now you also put the secondary spring tighter in 2-2 mode and its a Rabid Chainsaw!!
Old 07-14-2011, 02:30 PM
Cbystrack's Avatar
Member #15015
okay great thanks for the responce, i just ordered a red spring for the clutch. now secondarie spring tension... how do i go about adjusting it?
1987 polaris 250 what should compression be
2001 polaris trailblazer /secondary clutch spring position
has been asking and has asked
polaris atv clutch spring yellow
polaris trail blazer yellow spring
polaris trailblazer changing primary clutch spring
polaris trailblazer lower clutch engagement
polaris yellow atv spring
position clutch spring trailblazer
stock spring colors on polaris trailblazer
probably asked and answered Jacob bo ATV Repair and Maintenance 6 02-06-2011 06:45 PM
