Old 06-12-2011, 05:09 AM
4everfrio's Avatar
Member #15902
trailblazer or trailboss ????
Howdy. I am a new member. Can someone tell me the difference between a 93 trailboss and a 93 trailblazer 250 4x4. One more ?? Where can I find a seat for one of these machines ?? thanks
Old 06-12-2011, 05:41 AM
Old 06-12-2011, 07:41 AM
Bigdog800EFI's Avatar
Member #14008
I owned a 93 Trail Boss and it was a 350, not sure if that helps, never heard of a 93 TrailBlazer
Old 06-20-2011, 06:33 PM
mingojr's Avatar
Member #15780
Bigdog800EFi, I think you are right. , don't think they made a 250 trail boss and a 250 trail blazer in the same year
Old 06-20-2011, 06:55 PM
M_Quick's Avatar
Member #13816
They make them now, and they are 330cc motor's. The only difference on the newer models are the Trail boss has front and rear rack's.
2001 Polaris Scrambler 500 4x4
(2) 2003 Polaris Sportsman 90cc
2006 Polaris Predator 50
2008 Honda Trx700xx
Old 06-20-2011, 08:56 PM
polaris2000's Avatar
Member #16177
ebay for the seat
Old 09-18-2011, 04:14 PM
minidaredevil1999's Avatar
Member #18779
the differences i know are that, the trailblazer is a little lower than the boss. also many say the blazer are in better shape and are worth more. thats all I've heard. truthfully i like the blazer better.
Old 09-20-2011, 04:09 PM
M_Quick's Avatar
Member #13816
Manufacturer Polaris
Model Year 2012
Model Trail BossŪ 330
MSRP $4,399.00*
DIMENSIONS
Length 75 in. (190.5 cm)
Height 49 in. (124.5 cm)
Width 45 in. (114.3 cm)
Weight 531 lbs. (239 kg)
Ground Clearance 4.75 in. (12.1 cm)
Wheelbase 48.5 in. (122 cm)
Seat Height 35 in. (89 cm)
ENGINE
Engine 4-stroke, 1-cylinder
Displacement 329 cc
Carburetion Carbureted
Fuel Capacity 4 gal. (15 l)
Cooling Air with fan assist
DRIVETRAIN
Transmission Automatic PVT F/N/R
Drive System 2x4
Drive 2WD
Final: Concentric chain
BRAKES/WHEELS/TIRES
Brakes Front: Single lever hydraulic disc
Rear: Hydraulic rear foot
Parking: Lockable hand lever
Wheels Stamped steel
Tires Front: 23 x 8-12; 489
Rear: 22 x 11-10; 489
Model Year 2012
Model Trail BlazerŪ 330
MSRP $4,399.00*
DIMENSIONS
Weight 492 lbs. (223.2 kg)
ENGINE
Displacement 329 cc
DRIVETRAIN
Drive System 2x4
Drive 2WD
BRAKES/WHEELS/TIRES
Brakes Front: Single-lever hydraulic disc
2008 Honda Trx700xx
2008 polaris scrambler 90cc
250 polaris trailblazer vs. trailboss
did polaris make a ranger 330
difference between polaris trailblazer trail boss
difference between polaris trailboss and trailblazer
difference between trailblazer and scrambler
difference in trail boss and scrambler polaris
do all trailblazer 250s got the same transmission
is a 250 trail boss and 250 trailblazer same engine
polaris trail blazer & trail boss difference
polaris trail boss vs trail blazer
polaris trail boss vs trailblazer
polaris trail boss vs. trailblazer
polaris trailblazer all years the same??
polaris trailblazer vs polaris trail boss
trailblazer 250 years made
what is the differance between a trail boss 250 and 2x4
what is the difference between a polaris trail boss and trail blazer
what is the difference between polaris trail boss and trail blazer?
what years did polaris have a 330 atv
85 250 trailboss 2x4?? i think maybe? flashburn ATV Repair and Maintenance 10 02-12-2011 01:41 PM
330 Trailblazer or Trailboss for $5 huckfinn ATV Purchasing and Price 2 06-21-2010 05:35 PM
Trailboss needs more get up and go mrbartender ATV Performance Modifications 6 05-26-2010 09:33 AM
330 trailboss no run wetdirt ATV Repair and Maintenance 9 04-04-2010 08:45 PM
Trailboss 330 rifle ATV Performance Modifications 2 01-11-2010 03:54 PM
