07-03-2011, 01:55 PM
Member #15334
'01 Trail Blazer misfiring, dying ???
I have been trying to fix my neighbors trail blazer for over a week now, it was sitting for 3 years, and I have fixed all the problems it has, I cleaned the carburetor out completely, new fuel, new oil, cleaned out the oil tank and delivery line/filter and the fuel lines and filter, new plug, and new air filter, I had it going perfectly, then I noticed it was getting hot pretty fast, and after about 15 minutes of riding around, it stalled on idle, and it was like half seized up, very hard to pull over, and very hot, I let it sit for an hour to cool down, and it does the same thing again after riding for 15 minutes. I thought it was the fuel mix, so I turned the screw 1 turn out and went from there to see where it should be, cleaning the plug off with a wire brush between attempts, but now I can't get it to go anywhere, it just misfires, bogs, and dies when I try to get it moving, no matter where I turn the screw to. what is the proper amount of turns out for the screw? or could it be another issue? I am completely guessing here. I am about to chuck this quad in a lake and get back on a 4 stroke, so any help would be appreciated.
cheers
1998 Polaris Magnum 425
Kenda Bear Claw Tires - 3000lb winch
07-03-2011, 07:03 PM
07-03-2011, 11:56 PM
Member #3702
Is the oil injection pump working? It may be overheating due to lack of oil. Check here for more info. Service manuals
2005 Predator
Stage 1 Hot Cams CFM oil tank UM nerf bars and heel guards
Pro Aluminum skid plate and front bumper
Pure Polaris pipe K&N filter Jet Kit
Renthal bars, chain and sprockets Battery relocated
Civic style intake
1997 Trailboss
Jet Kit DG pipe
Modded cylinder fitted w/ 400 V-Force reed valve
Milled cylinder head
Namura piston and rings .040 over
Moose Racing gaskets
07-04-2011, 06:09 AM
Member #16484
picnch the oil line. mix the gas quick way to see if it is the oil pump not working
07-06-2011, 02:42 PM
Member #15334
sorry I haven't been able to get on here in a bit. Thanks Bruce, I should be on here more.
And I took the top end off the engine and the cylinder is scored all around..... Looks like this is going to be a money job. Thanks for the help guys.
07-12-2011, 07:26 PM
Member #14895
cheers
My 2000 T-blazer does the exact same thing. Runs beautiful for 15 minutes, and then when it warms, it gets hot about 4-5 minutes later and can't hold idle. Then it doesn't want to start until it cools. When it cools completely, same thing, runs perfect for 15 minutes, then same crap all over again. New plug, oil, cleaned carb, air filter, new fuel, etc. My mechanic told me the choke was stuck open half way and thought that might be the problem. He fixed that and same problem.
2008 Can Am Outlander 800 Max XT Ltd.
HMF Swamp XL
Power Commander III
Snorkel your ATV snorkel kit
2005 Polaris Trailblazer 250
Stock (Shared ownership - that's why stock)
2000 Polaris Trailblazer 250
Stock - But not for long
01 blazer 4.3l hard to start and misfiring, 05 polaris trailblazer 250 intake snorkel, 1997 polaris trail boss acts like its misfiring, 2005 polaris trailblazer250 stalls, 2010 polaris trail blazer overheated, jet kit 04 polaris trailblazer, namura piston for polaris trailblazer 250, overheating on polaris 330 atv, polaris 250 scored piston, polaris scrambler 250 misfire timing, polaris scrambler 90 misfiring, polaris trail boss 250 overheating, polaris trailblazer 250 nerfbars, polaris trailblazer namura piston kit problems, polaris trailblazer rings and gaskets, polaris trailblazer sigma jet kit, polaris trailblazer stalls, polaris trailblazer stops when hot, stock gearing polaris trail blazer 250, where are the power reed on a polaris trailblazer
