Old 07-11-2011, 12:51 PM
boogienut77's Avatar
Member #16694
polaris rebuild
Hi im new here and I have a 96 trailblazer that i am trying to rebuild for my dad. I have it ripped down to the bottom end but still in the quad. the quad shattered the piston skirt and put aluminum fragments all through everything. I am trying to get the clutch assembaly off of the block so I can flush the bottom end out and see what all is bad but I cant figure out how to remove the clutch? any help would be appreciated! thanks
Old 07-11-2011, 01:28 PM
Member #16694
Thumbs down
anybody home?
Old 07-11-2011, 01:52 PM
tt425's Avatar
Member #3687
You will need a Polaris primary clutch puller. You can buy aftermarket puller for around $20-30. Or build it. I don't remember the size diameter of bolt 5/8" or 3/4" fine thread about 10" long. Get a piece of all thread rod with a nut welded to it. First remove the bolt in the center of clutch. Then thread the puller into the hole and tighten and the pulley will come off.
1995 GMC 1500 Ext. Cab Z71( new motor 3 yr warranty unlimited mileage, on the road again)
2008 Pontiac Grand Prix
1996 400 Explorer 4x4( project purchased 12-30-11)
1995 425 4x4 Magnum
1998 Sportsman 500 4x4(parting out)
1999 Kawasaki 220 Bayou 2wd
Old 07-11-2011, 02:03 PM
Member #16694
so is the primary clutch threaded onto the crank or is it a press fit? the way you explained it it sounds like it is has left handed threads and turns off. is that correct?
Old 07-11-2011, 02:43 PM
tt425's Avatar
Member #3687
It is a press fit. It has a bolt holding it on in the center. Remove that bolt. It has about a 9/16" or 5/8" head on it. After removing that bolt thread the puller(threaded rod) into the clutch. The threads hold the clutch and as it bottoms out on the crank it will press the clutch off the puller. It is right hand threads. The slotted nut on the flywheel side of the engine is sometimes left hand thread. I hope this makes sense.
1995 425 4x4 Magnum
Old 07-11-2011, 03:03 PM
Member #16694
yep that pretty much cleared it up. im kinda new to the polaris setup but im learning
Old 07-11-2011, 04:07 PM
tt425's Avatar
Member #3687
You will learn. I learn everyday and been working on 4 stroke Polaris for about 12yrs now. I have a total of 11 4 wheelers and all but 1 are Polaris. Most of them I am parting out and thats when you start learning. LOL.
Good Luck on the rebuild.
1995 425 4x4 Magnum
Old 07-11-2011, 05:11 PM
mingojr's Avatar
Member #15780
Yes sir re bob. am doing the same rebuild for the second time on this 96 250 TB. There is a special puller for that job!!! Do not try anything to get that clutch off without the proper puller. I did find a friend that had the right puller and he let me use it. Works great and it's real easy. I just put the clutch assembly back on and finally got the piston and rings back in the cylinder today. That's a tuff one
Old 07-12-2011, 12:49 PM
Member #16694
Thanks for all the help guys! this is my first polaris build. it was my boys quad till it blew up then i decided to get him something a lil more his size and a lil more sporty so i got him a 300ex and he loves it. then i decided to try to bring the 250 back to life and give it to my dad. Id like to get my mom and dad out with me and the wife and kids. I got the whold family outfitted now. I run a yamaha yfz 450 r, my wife runs a yamaha 350 warrior, my sone has the honda 300ex and my lil girl runs a kasea 90. heres a lil video i made of my family riding with our friends. if you dont like metal music turn it down! lol.
1993 polaris 250 4x4 head bolts torque
1994 polaris 400l 4x4 flywheel nut
1995 sportsman 300 piston
1996 polaris xplorer 300 clutch puller
1996 polaris xplorer 300 cylinder head
94 polaris 300 rebuild
bolt size for flywheel puller 1995 polaris magnum 4x4
how to get remove cylinder from block on polaris trailblazer atv
polaris 250 bottom end rebuild
polaris 250 trailblazer hole in piston
polaris 300 4x4 piston
polaris 300 atv head bolt torque
polaris 300 head torge
polaris 90 head torque
polaris magnum 350 rod
polaris xplorer 400 primary clutch torque
rebuilding bottom end polaris 250 motors on youtube
u tube polaris rebuild
what size is bolt in polaris xplorer dive clutch
xplorer 300 head bolt size
rebuild trailboss93 ATV Repair and Maintenance 2 05-22-2011 07:58 PM
Polaris xplorer 300 recent rebuild but more questions stingertrey ATV Repair and Maintenance 1 05-09-2011 05:37 PM
850 rebuild wildbill71457 ATV Repair and Maintenance 1 04-24-2011 05:23 PM
99 polaris 250 no start after rebuild 61brown61 Polaris Trail Blazer 4 02-08-2011 01:51 PM
carb rebuild kid for 95 polaris taills64 Polaris Magnum 2 09-14-2010 08:08 AM
