engine revving on its own.
so i took out the carb from the 1999 250 trail blazer i just bought and cleaned it up and fixed the issues of it bogging when throttle was applied. i went in the house for a little bit and came back to work on it some more and started it up and it starts great, but it revs like i am mashing the throttle. just keeps revving higher and higher. i did mess with the throttle after i cleaned the carb and tightened up the return spring a little bit. but when i work the throttle, everything works as it should, as i can see the cable moving in and out where it enters the engine. so i do not think that is it. any ideas? thanks!
