07-14-2011, 02:34 PM
Member #15015
swing arm bushings???
2001 polaris trail blazer if i go to tighten the chain i find that my swing arm has ALOT of slop. with it in the air i can hold the rear tires and move the swing arm back and fourth... now my questions are
do i need the new rubber bushings
example- REAR SWINGARM BUSHINGS POLARIS TRAILBLAZER 250 99-05 | eBay
or do i need this??? - Swing Arm Bushing Kit - Polaris Trail Blazer, Sportsman | eBay
let me know so i can order it. thanks for looking!
2001 Polaris trailblazer 265 2wd......its good enough for me!
1987 Camaro Iroc-Z 367 4 bolt main.....its slow
07-20-2011, 04:39 PM
Member #15015
can anyone help?
07-21-2011, 08:35 PM
Member #16887
Looking at the two kits the second one does not fit your machine
03-17-2012, 03:25 PM
Member #24301
if they dont make the bushings anymore you may have to take them out and have a machine shop make some up. I had to do that with my 92 Polaris 350 L. the part that I would normally call a bushing is actually called a bearing. its a hard "plastic" piece that the steel bushing fits inside. you can probably still buy the bearing at your dealer. I picked a set up and they were $11 each. I took my old bushings to a machine shop and they turned them out for $15 each. Hopefully this helps you out a little bit. Oh and you need the seals also which go on both sides of the bearing. Good luck
03-17-2012, 04:14 PM
Member #23426
This thread is a couple of months old.
There are no seals on the swingarm bushings. There is next to the axle bearings but not the swingarm bushings.
And mine had simply come loose. I cleaned them thoroughly, used Loctite on the threads, and torqued it to the correct 150 foot pounds.
03-17-2012, 04:19 PM
Member #24301
well its for sure mine is a lot different than your then. mine has seals to keep the grease in and the water out
03-17-2012, 07:45 PM
Member #23426
Mine is a 2003 Trail Blazer.
I also have a 1999 Trail Blazer that looks identical in the swingarm mount.
Here again, OP was referring to the Trail Blazer's swingarm pivot bushings, not the axle bearings which do have seals.
03-17-2012, 07:51 PM
Member #24301
I know what a swing arm is I've got mine off my 92 trail boss 350 and it has swing arm bearings, bushings, and seals. I'm not talking about the axle. I thought maybe his might be built the same and that's why I posted on the thread in the first place
99 polaris trail boss swing arm loose, changing polaris trailblazer swingarm bushings, how to change polaris swingarm bushinings, how to change rear swingarm bushing on a 2003 polaris trailblazer, how to change swing arm bushings on 2001 polaris trailblazer, how to change the swingarm bearings on a polaris 350, how to remove rear swing arm on polaris atv, how to remove rear swingarm polaris atv, how to replace rear swing arm bushings polaris explorer, how to take 2001 polaris 250 trailblazer swingarm off, polaris swing arm bushings, polaris swingarm updates, polaris xplorer swing arm pivot kit, pulling swingarm polaris trailblazer, remove swing arm on polaris xplorer, removing polaris swingarm, removing swingarm on polaris trailblazer, replace the rear swing arm on a polaris outlaw, replacing swingarm bushings polaris xplorer, trailblazer swingarm
