Old 07-17-2011, 03:54 PM
BeefySTi's Avatar
Member #16741
rear brake
Anyone tell me if the rear brake on a 1998 Trail Blazer 250 is mechanical or hydraulic? i know the front brake lever works all the brakes hydraulically, but when you step on the brake pedal, it rotates the piston actuator or whatever it is called. I am just wondering if the piston actuator pushes directly on the piston, or if the actuator pushes fluid to activate the piston. I am having an issue with the rear brake. When you push the pedal, it doesnt create enough pressure to really stop the atv effectively. the caliper barely causes the pads to move when the pedal is pushed as far as it can go. the brake lever on the other hand seems to move it a lot more. I am just trying to trouble shoot. any input would be great, thanks in advance!
Old 07-17-2011, 04:12 PM
BeefySTi's Avatar
Member #16741
forgot to mention i bled the rear caliper and couldnt get any bubbles to come out, so i do not believe it is air in the line.
Old 09-18-2011, 05:04 PM
nikkihtilley's Avatar
Member #18590
Well from what ive ever heard the rear foot brake is more of an ornimental thing than an actual usable part lol.
Nikkih
Old 09-20-2011, 04:46 AM
Bait's Avatar
Member #8552
You can adjust the foot pedal arm tention by the allen head screw that goes into the caliper, It wasnt designed to stop the bike by using the foot pedal but mearly a "hold in place" so you can remove your hand off the brake handle to do what ever while sitting still. Now if you are having issuse with the hand break not working properly then you should start troublshooting that which is normally either a clogged line or a bad caliper.
but to answer your orignal question the rear caliper is both hygrailic and mechanical
1998 trail blazer rear brakes
adjusting brakes on polaris trail blazer
adjusting rear foot brakes on a polaris atv
atv rear brakes not grabbing enough
fix rear brake on polaris trailblazer
foot brake for polaris trailblazer
how to fix foot brake on 2001 polaris trail blazer
polaris 250 blazer foot brake
polaris 250 trailblazer rear brake
polaris brake actuator
polaris brakes bleed
polaris fourm brakes
polaris rear brake actuator
polaris trailblazer foot brake
polaris trailblazer rear brake fix
polaris trailblazer rear brake upgrade
polaris trailblazer rear brakes do not work
poplaris trail blazer brake mod
rear calipers not grabbing enough -- why
Rear brake question Billyd Polaris Predator 11 04-06-2011 01:07 PM
Weak Rear Brake Cold_and_Tired ATV Brakes & Suspension 12 04-06-2011 05:52 AM
Rear brake not working 04Silverado ATV Brakes & Suspension 10 02-17-2011 05:39 AM
rear brake two as one Around The Garage 6 01-12-2010 01:22 PM
chattering rear brake firedude26 ATV Brakes & Suspension 3 05-21-2009 05:07 PM
