07-18-2011, 02:46 PM
Member #16902
what kind of engine oil?
I just got a 2002 trailblazer and would like to know what kind of engine oil is required? I cant seem to find the answer on the site.
thank for your help
d
07-18-2011, 04:51 PM
I should know this, but I am not sure. Is this a 250 2-stroke or 330 4-stroke? If 2 stroke, any synthetic 2-stroke oil will be fine. If a 4-stroke, any synthetic 0w-40 4-stroke oil will be fine. I believe amsoil and mobil 1 both make it
07-18-2011, 05:06 PM
Member #16902
thanx--its the 2 stroke.
were tearing down right now and kinda learning as we go.
07-18-2011, 05:07 PM
Member #16902
how much oil is needed for a change?
07-18-2011, 07:33 PM
2-strokes do not ever need oil changes. they burn their oil as they go. Its rare to see the oil injection pump fail, but many people will buy block off plates for them and just premix the gas. You need to find out of the oil injection pump is working. If it is, you just fill the oil reservoir full (its under the cap on the front fender area) and the machine will mix its own oil with its fuel. If the pump isnt working or has been blocked off, then premix the fuel to about 32:1 before it goes into the machine.
Either way is fine. Just always make sure the gas is either premixed properly or the oil tank has oil in it, or it will seize up fast. One tank of oil should last a few tanks of gas.
You will have other fluids that need regular changing thought like the gearcase.
08-04-2011, 05:56 AM
Member #17240
how can i check to see if the pump is working?
04 polaris trailblazer where to fill oil, 1998 polaris trailblazer oil for engine, 2 stoke polaris oil change, 2002 polaris trail blazer oil, 2002 polaris trailblazer 250 oil injection, polaris atv engine oil, polaris quad 250 oil type, polaris trailblazer 25 is it a 2 stroke or a 4 stroke engine, what kind of engine oil on 04 polaris 250, what kind of engine oil on polaris 250, what kind of oil do i put in a polaris trailblaze 250, what kind of oil do i put in a polaris trailblazer 250, what kind of oil does a 2 stroke polaris take, what kind of oil does a 2002 polaris take, what kind of oil does a 4 stroke atv take ?, what kind of oil does my 2002 polaris trailblazer use, what kind of oil for a 2 stroke atv, what kind oil does a polaris four stroke used, what type of 2 stoke oil does a polaris 250, what type of oil does my 2 stroke poleras 250
