08-10-2011, 01:33 PM
Member #6437
1996 Trail Blazer Carb Picture
Anyone have a picture of these carbs with details of what the parts are? Jets,Idle Screw,choke ETC?
I have a clogged Carb and need to know what it takes to take it off and what the parts are so I can use the writeup that describes how to clean it. I have the writeup just not familiar with the parts. Any help is appreciated. I think I can figure it out if I get the carb off I guess. Thanks. <===Lefty===
08-11-2011, 04:37 AM
Member #3687
Go to a polaris parts website such as babbittsonline.com click on atv parts,polaris, year, model, then carb. After doing that you can zoom in on the picture to see it better.
08-11-2011, 04:58 AM
Member #6437
Thanks I will give that a try. Going to pull it off today.
08-11-2011, 11:37 AM
Member #6437
After taking out the carb and cleaning it I put everything back in and still no go. Found out I wasn't getting any fuel to it. Took out the Switch(on/Off) and cleaned it 2 times and still no go. I then blew through it and found inside the switch was clogged and I couldn't get it fixed. Went down and bought a new one and now after adjusting the carb I have it running good again. I will never leave an ATV sit that long again without adding Stabil to the gas.
08-11-2011, 01:03 PM
Member #3687
Glad to hear you got it going. It is always good to use a fuel stablizer. Ethanol in the gas is causing alot of problems with carb engines.
08-15-2011, 04:44 PM
use SEafoam in it 4 or 5 times a year and it will help stabilize and does a good job of keeping things clean
08-21-2011, 08:53 AM
Member #13967
I have had fair luck with these websites. There are several. The pictures are okay for figuring out where that extra part goes, and most things are somewhat named. My problem is that some things aren't named. Example: for my ATV carb, there is a part that I need to know what it is. The name is "adjuster". Okay...for what??? Another one I found was "screw". It's not actually a screw, it is an adjusting screw, but for what???
Anyway, it's a good reference to a point.
Spence
2001 Trail Boss 325, AA model, since April 2011
"I've been sane, and I've been crazy. Crazy is more fun!"
08-22-2011, 10:43 AM
Member #6437
Originally Posted by broman
Thanks Bro Man, That is a great link.
1996 polaris 250 trailblazer carb detail, 1996 polaris carburetor, 1996 polaris trailblazer, 1996 polaris trailblazer 250 carb, 1996 polaris trailblazer 250 parts, 1996 polaris trailblazer 250 specs, 1996 trailblazer, 1996 trailblazer pictures, 250 trailblazer carburetor, carburetors models for polaris trailblazer 250, free polaris photo atv carbs, polaris 250 carburator size, polaris 250 trailblazer carburetor, polaris blazer parts 96 model, polaris trail blazer carb, polaris trailblazer 250 carb, polaris trailblazer 250 carburetor, polaris trailblazer 250 carburetor diagram, polaris trailblazer carb cleaning, polaris trailblazer carburetor
