Old 08-30-2011, 11:19 PM
chas400sport's Avatar
Member #18200
Installing starter, Problem getting recoil starter assembly off.
I came here hoping that someone could give me a little help with getting the recoil starter off of my wifes 1998 250 Tral Blazer.
I'm installing a new starter in it and I know what parts need to be removed.
I have the skid plate, belt housing and clutches off, but I can't get the recoil starter assembly off. I have removed all six bolts and I think it is just stuck to the engine case. I have beat on it and pried on it and I'm afraid I will break it.
Anybody know how to get it loose. I talked to mechanics at shops near me and they say hey usually came right off.
Old 08-31-2011, 12:20 PM
lefty's Avatar
Member #6437
The bad thing is,some people think using an adhesive is the only way to go. If you can heat it up some around it that might do it. Not too hot though.
Old 08-31-2011, 12:44 PM
lefty's Avatar
Member #6437
Had me thinking so I went out and checked. I have a 96 and a 97. The 96 screws were loose and so was the case.
Old 08-31-2011, 12:49 PM
broman's Avatar
Member #17544
Sounds like you're doing it correctly. Mine took a whack or two from a rubber mallet and then came off pretty easily. I second the head suggestion. Or spray some Wd-40 or some kind of gasket remover around it and let it sit for a while.
Old 08-31-2011, 04:23 PM
ATVJason's Avatar
Member #18214
I have the skid plate, belt housing and clutches off, but I can't get the recoil starter assembly off. I have aftermarket parts all six bolts and I think it is just stuck to the engine case. I have beat on it and pried on it and I'm afraid I will break it.
Haha. I thought I was the only one who would dare to whack it(thats what she said). lol.
Old 09-01-2011, 08:39 AM
Member #18200
Yesssss! I got it off!
Thanks a lot guys for taking the time to help me.
I am sure glad I found this forum.
broman's suggestion to use WD-40 did the trick. I just soaked the hell out of it and sat back for awhile and was able to pry it right off. I beat it first with a large rubber mallet and that did nothing. I had to pry it away from the case in the front, using the frame as a fulcrum.
I didn't have to try it, but I think lefty's idea about heating it would work.
Thanks again
Old 09-01-2011, 08:47 AM
lefty's Avatar
Member #6437
It's always good to know when someone gets a difficult task done.
01 polaris recoil starter disassembly tool
01 polaris trailblazer starter problems
1998 polaris recoil issues
98 polaris 500 recoil removal
atv starter assembly
how do you fix a recoil on a 1998 polaris trail blazer
how to assemble polaris recoil starter
how to disassemble polaris trailblazer recoil starter
how to install a solenoid of a polaris trailblazer
how to install polaris starter relay
how to install starter solenoid for polaris atv
how to pull a recoil off a polaris atv
how to recoil a polaris trailblazer 250 go
how to replace a starter on 03 polaris atv
how to take a starter off a polaris trail blazer
installing starter solenoid for polaris atv
polaris scrambler 400 starter stuck
recoil starter 04 trailblazer 250
recoil starter issue polaris atv
removing trailblazer 250 recoil
rebuilding a pull rope starter or recoil starter? booger68 ATV Repair and Maintenance 4 12-23-2011 03:13 PM
Recoil starter problem..... Jsleboda15 ATV Repair and Maintenance 3 09-01-2011 10:40 AM
!998 Trailblazer Problem installing starter chas400sport ATV Repair and Maintenance 2 08-31-2011 01:18 PM
Problem with recoil starter michaelbell85 Polaris Scrambler 3 04-14-2011 03:25 PM
starter problem ??? or starter drive ?? mgg403 ATV Repair and Maintenance 1 07-12-2009 05:17 AM
