Old 10-30-2011, 03:39 PM
96trailblazer's Avatar
Member #12157
how to replace strut
Not a good day, a bolt must have fallen off the bottom of my front shock where it connects to the a-arm, causting my front wheel to basically come off, the front to nose dive, and me ending up pinned under it. Now I can see the strut snapped at the top, so my question is how do I just replace the strut? I thought I was going to have to replace the entire thing, but it looks like the strut will just come out but not sure how. If you have a pic. or something that would be great. I will see if I can post a pic. too. Thanks.
Old 10-30-2011, 04:13 PM
Member #12157
Ok, that was easy enough. Now I just need to get the new one, and I should be back on the trails in no time!
changing a front strut on a polaris atv
changing front struts polaris atv
changing polaris fornt struts
changing struts on a trail blazers
how do you replace struts on atv
how to change strut on polaris
how to change strut on polaris sportsman
how to remove front struts on polaris trailblazer
how to replace front shocks on a polaris
how to replace front struts polaris trail blazer
how to replace polaris struts
how to replace struts on polaris atv
polaris atv strut change
polaris strut change
polaris trailblazer front shocks
relace front strut polaris
removing front struts from a polaris sportsman
replace piston or not? atvman2010 ATV Repair and Maintenance 2 02-11-2011 01:32 PM
Replace coolant mg8002x Polaris Sportsman 3 12-19-2010 07:13 AM
Do you have to replace both calipers? JoshH ATV Brakes & Suspension 3 09-27-2010 03:25 AM
how do i replace the bearing? rebelrider ATV Repair and Maintenance 3 07-13-2010 03:56 PM
a arm came out of strut. dan the man ATV Brakes & Suspension 3 06-28-2010 07:19 PM
