This is the procedure out of my manual for the proper oil pump/cable adjustment.
Hope this helps, Buddy.
OIL PUMP ADJUSTMENT
PROCEDURE
1. Before adjusting the oil pump, check engine idle
RPMand set to specification. Adjust if necessary.
2. Check and adjust throttle lever free play (ETC
switch).
3. Place gear selector in neutral and apply parking
brake.
4. Start the engine and let it idle.
5. Place very slight pressure on the throttle lever
until all freeplay is removed from throttle cable to
carburetor (to the point where the carb slide is just
starting to rise and engine RPM begins to
increase).
6. Loosen locknut .
7. Turn adjuster in or out until all freeplay is
removed from oil pump cable (the point where the
oil pump arm is just starting to move off of its
stop).
NOTE: The pump stop keeps the pump arm from
rotating any farther down than the idle position so no
visual alignment of marks is necessary.
8. Tighten the locknut.
1999 Sport 400 2x4
Complete rebuild w/Wiseco piston by Todd Kerby
Comet clutch
Swamplites front & rear
03 Predator Rear Hubs
ITP Pro Baja Wheels (4x156 front & rear)
DG Front Bumper
Fuj Rear Grab Bars
