Old 11-19-2011, 01:52 PM
Greenmoney217's Avatar
Member #20511
Please Need help with no brakes
I have a 1999 polaris trailblazer 250 and i just replaced brake pads and i went to bleed the front brakes i couldnt get pressure i bleeded the all calipers and i am getting a leak from the rear brake reservoir its pushing brake fluid out of the reservoir just bought a new rear reservoir
So please if you have any advise i would greatly apprieciate!!!
what could this be ???
Old 11-19-2011, 05:01 PM
buddy_1's Avatar
Member #15674
You need to overhaul/replace your rear caliper. The piston seals are leaking and causing fluid to by-pass from the main system(hand brake) into the auxilary system(foot brake). Needless to say, (depending on your skill level) overhauling would be cheaper. Also, keep in mind that buying used can be iffy due to the fact that you could be buying someone else's problem. Good luck, Buddy.
1999 Sport 400 2x4
Complete rebuild w/Wiseco piston by Todd Kerby
Comet clutch
Swamplites front & rear
03 Predator Rear Hubs
ITP Pro Baja Wheels (4x156 front & rear)
DG Front Bumper
Fuj Rear Grab Bars
Old 11-19-2011, 07:23 PM
Old 11-20-2011, 01:18 PM
Member #20511
i cant seem to find a rebuild kit for my rear caliper do you know where i can find it ....is there any way to bypass this brake system like on my kfx 400 front brake system and rear brake system that are seperate is there a way i can just seperate my front and rear brakes as they are connected isnt there a hose i can block off from the rear caliper to the front so i can just bleed the front brakes i really need my quad
Old 11-20-2011, 02:12 PM
buddy_1's Avatar
Member #15674
Go to OEM Parts Polaris TRAIL BLAZER 250 (A99BA25CA) 1999 REAR CALIPER MOUNTING - A99BA25CA - Cheap Cycle Parts call out #2 2201385 KIT,SEAL,CALIPER $34.03 plus shipping. Also check out http://partsfinder.onlinemicrofiche....=13&A=148&B=24
1999 Sport 400 2x4
Comet clutch
DG Front Bumper
Fuj Rear Grab Bars
Old 11-20-2011, 02:26 PM
Member #20511
is there any way i can bypass rear brakes so my front ones work need my quad for hunting dont really need brakes to pull a deer out but i do have a few hills i go down and need something to slow me down just a quick fix till i get new seals....
Old 11-20-2011, 02:32 PM
buddy_1's Avatar
Member #15674
I've read about a couple of guys doing it but never tried or seen it done.
1999 Sport 400 2x4
Comet clutch
DG Front Bumper
Fuj Rear Grab Bars
Old 11-20-2011, 03:05 PM
buddy_1's Avatar
Member #15674
Try following this link to Gen3USA and see if it will let you look Gen3USA :: Log in . If not log in as a guest and go to the how to section. Once there look at the sticky for DIY Split Brake Conversion.
1999 Sport 400 2x4
Comet clutch
DG Front Bumper
Fuj Rear Grab Bars
Old 11-20-2011, 03:42 PM
Member #20511
did you see it there cause i cant get registered cause no authorization code where do i find that sorry
Old 11-20-2011, 05:24 PM
buddy_1's Avatar
Member #15674
On the home page it says to use: atvnuts
1999 Sport 400 2x4
Comet clutch
DG Front Bumper
Fuj Rear Grab Bars
03 polaris trailblazer 250 brake bleeding
1999 polaris trailblazer 250 rear brakes
bleading brakes on 99 polaris trailblazer 250
bleeding brakes polaris trailblazer
bleeding polaris trailblazer 250 brakes
calibars for 250 trailblazer polaris
how do i bypass rear brakes
how to bleed brakes on a polaris trail blazer
how to bleed brakes on a polaris trailblazer
how to bleed polaris atv brakes
how to bleed polaris trailblazer front brakes
polaris trailblazer 250 brake fluid reservoir
polaris trailblazer 250 foot brake reservoir
polaris trailblazer 250 front brake fluid
polaris trailblazer 250 no brakes
polaris trailblazer 250 no front brakes
polaris trailblazer brakes dont work
polaris trailblazer foot brake
trailblazer 250 back brakes bleed
trying to bleed brakes on a polaris trailblazer
Help Brakes Stevehi ATV Brakes & Suspension 3 11-21-2011 08:04 AM
ebc brakes skiboat Polaris XP 1 05-25-2011 11:11 AM
850 brakes frye7077 Polaris XP 0 01-30-2011 04:17 PM
04 atp 330 brakes NotQuik ATV Brakes & Suspension 1 05-24-2010 12:50 AM
brakes on 09 xp 550 kohen ATV Brakes & Suspension 2 05-03-2010 04:28 PM
