Old 11-29-2011, 06:35 AM
mr4x4king's Avatar
Member #17460
2005 trailblazer 250 idle
i can not get the idle to go down
if i turn the idle screw left or right it does not change
and ideas?
is it time to rebuild the carb?
i have looked for rebuild kits but i can not find one for a 2005
let me know
thanks!
Old 02-09-2012, 04:18 AM
mr4x4king's Avatar
Member #17460
wow nobody answered since november
1999 Polaris Scrambler 400 4x4
1998 Polaris Trailblazer 250
2005 Polaris Trailblazer 250
Old 02-09-2012, 06:20 PM
beaverclever02's Avatar
Member #22889
Id say start by looking for an air leak, spray some carb clean around the outside of the boots. After that you may look at pilot jetting
Old 02-10-2012, 07:20 AM
factionfx's Avatar
Member #20681
Air leak, throttle cable needs to be lubed, or throttle cable is adjusted too tight.
2012 Sportsman 500, Red.
03 250 polaris trailblazer carb tuning
05 polaris trailblazer 250 carburetor parts
2000 polaris trailblazer idle s rew
2005 polaris trail blazer 250 carbeurator
2005 polaris trailblazer 250 carburetor
2005 polaris trailblazer 250 sprocket
2005 polaris trailblazer carburator rebuild
how to adjust a polaris 250 carb
how to adjust iddle on polaris 250
how to adjust idle 2005 trailblazer
how to clean carburetor on 02 trailblazer
how to clean the carb on a 1999 polaris trailblazer 250
how to rebuild trailblazer 250 rear shock
polaris 250 jerky idle
polaris trailblazer 250 2006 carburetor adjustment
polaris trailblazer 250 carb adjustment
polaris trailblazer 250 will not idle
trail blazer 250 forums
trailblazer 250 carb forum
trailblazer 250 stock carb settings
04 polaris trailblazer idle and rear brake issues trailblazerMMP04 ATV Brakes & Suspension 10 02-23-2012 02:06 PM
2005 Sportsman 400 won't idle foolhardy ATV Repair and Maintenance 11 02-25-2011 08:00 AM
02 Trailblazer 250 will not idle clayc102 Polaris Trail Blazer 2 05-01-2010 06:47 PM
Trailblazer wont idle and bogs 3 Polaris Atvs Polaris Trail Blazer 2 04-19-2010 07:19 PM
2000 Trailblazer rough idle/sputtering psavas Polaris Trail Blazer 3 04-17-2010 03:19 PM
