  #11 (permalink)
Old 01-19-2012, 08:08 AM
factionfx's Avatar
Member #20681
the 2004 TB rear foot brake is hydraulic; it is in a seperate system though from hydraulic hand lever brake, so bleeding the front brakes is not applicable to the problem he is trying to fix.
I should have mentioned to trace the hydraulic hose from the foot brake to the rear caliper to ensure you are bleeding the correct one
2012 Sportsman 500, Red.
  #12 (permalink)
Old 01-19-2012, 09:20 AM
Spdcrazy1's Avatar
Member #19504
I did make sure it was the right line. I did get some pedal but still no gripping the rear rotor. BTW the rear brake does work fine with the the hand brake.
2001 polaris trailblazer brakes not working
2004 polaris sportsman foot brake maintenance
adjust brake rear brake trailblazer 250
adjust rear brakes polaris trailblazer
adjusting rear foot brakes on a polaris atv
brake fluid for trailblazer 250
diagram of how to bleed polaris trailblazer breakes
how to adjust foot brake on polaris atv
how to bleed polaris sportsman foot brake
polaris atv brake not working
polaris brakes not working
polaris foot brake not working
polaris hydraulic break problem
polaris trail boss 250 rear brake adjustment
polaris trailblazer 250 rear brake problems
polaris trailblazer foot brake
polaris trailblazer foot brake not working
polaris trailblazer rear brake
polaris trailblazer rear brakes do not work
rear brakes don't work on polaris trail boss
Adjusting Rear Foot Brake jakes99trailboss Polaris Trail Boss 6 08-26-2011 12:51 PM
A rear brake pedal that WORKS! stefanj Polaris Magnum 4 06-13-2011 07:37 AM
Polaris Rear Foot Brake upgrade Hit.The.Gas ATV Performance Modifications 10 03-23-2011 02:05 PM
Rear brake not working 04Silverado ATV Repair and Maintenance 1 03-18-2011 04:48 PM
Brake Pedal kwaskow ATV General Discussion 6 03-08-2011 09:58 AM
