Old 01-22-2012, 08:41 PM
Jmannn's Avatar
Member #22577
Question 2001 Polaris 250 Trailblazer will run fine and then suddenly cut off...help please
Okay, so this is my first post. Nice forum btw with tons of awesome info!
So I am looking for help with my ATV my grandfather left sitting a while that was given to me. I cleaned out the carbs really well, drained all gas, and changed the plug. I have to jump start it because the batteries dead, but when I do it will run for about 45 seconds PERFECT with no misses or anything and suddenly it will cut off. Ive looked everywhere for answers and for the life of me cannot figure it out! It doesnt bog down and cut off, it just cuts off like the gas flow was suddenly stopped or something. Could the CDI box be the culprit? It ran fine when I got it until I hit a trail and it just cutoff and hasnt worked since even tho Ive cleaned carb, and changed the plug. Could the plug be fouling? I just want this thing running haha, where I live theres not much to do :P. I cant do compression tests because I dont have a meter, but when it ran it seemed like it had some umph except for the bogging it used to have at full throttle that it now doesnt. Do any of yall on here have any ideas? They would be greatly appreciated!
Thanks,
Jmannn
Old 01-22-2012, 08:54 PM
Jmannn's Avatar
Member #22577
Forgot to mention, the petcock has been replaced too. The old one leaked so we had to fix it
Old 01-22-2012, 09:34 PM
Old 01-23-2012, 03:30 PM
3inthedirt's Avatar
Member #9037
Try running it with gas cap off in case the vent is bad. Otherwise, you have a carb vent that is plugged. Remove it and soak it overnight with all rubber parts removed. Blow it out with compressed air. It's not running long enough for a coil or cdi problem in my opinion.
Old 01-28-2012, 09:07 AM
icefishur96's Avatar
Member #10391
Check your fuel filter. Make sure all your carb connections are tight as well.
2000 Scrambler 90
2008 Sportsman 500 H.O. EFI
2011 RZRs LE
Accessories from www.TheATVSuperStore.com
Tags
help!!!, polaris trailblazer, runs then dies
2000 polaris trailblazer cuts off in water
2001 polaris 250 trail blazer carburator parts
2001 polaris trailblazer
2001 polaris trailblazer 250
250 trailblazer runs if neddle is out
carb settings on a polaris 250 trail bazer
carburetor for polaris trailblazer 250
carburetor on a 250cc polaris trailblazer
fuel cut off switch polaris trailblazer
polaris 250 motor running hot
polaris 250 trailblazer
polaris 250 trailblazer carburetor
polaris 250 trailblazer just shut off
polaris 250 trailblazer stoped running
polaris trailblazer 250 carburetor
polaris trailblazer carb cleaning
polaris trailblazer gets hot then dies
poloris 250 trailblazer cleaning out carb
why trailblazer suddenly stop
will a starter disable trailblazer 250 to run
2001 trailblazer 250 einherzausstein Polaris Trail Blazer 3 10-09-2011 05:51 AM
need pics of carb 2001 polaris trailblazer afut11 Polaris Trail Blazer 1 10-24-2010 10:14 AM
need pics of carb 2001 polaris trailblazer afut11 Polaris Trail Blazer 0 10-24-2010 08:36 AM
2001 Polaris Trailblazer fuel petcock chevymuscle218 Polaris Trail Blazer 2 09-30-2010 01:22 AM
2001 polaris trailblazer tranny problems puppet ATV New Members 6 04-25-2010 07:31 AM
