Old 04-16-2012, 10:25 AM
andersonatvrepair's Avatar
Member #25326
Question 03 trailblazer starting problems
Hello I'm new here and I've been searching the web all day for answers and found nothing.
I'm working on a "03 Polaris Trailblazer 400" the reason for the quotation marks is that's what i figured out by the VIN and pic on Internet.
Problem i am having it will turn over all day long but never starts.
compression is running 80-85 psi
good spark @ plug and good fuel @ carb
this puzzle me a little
there is 2 cycle oil in the oil tank
and also premixed into gas ( was brought to me like this)
blows from exhaust and back of carb where the air filter goes. acts like it jumped time but everything I've read i don't think this thing has a "timing chain"
could i be looking at replacing the piston and rings?
any suggestions and help is appreciated in advance thanks
Old 04-16-2012, 10:30 AM
Bait's Avatar
Member #8552
yeah the problem is the rings are worn or a bad piston. The compresson is too weak and the blow back is due to the ring failure. Put a new top end kit in it and it will be fine. Also dont run both premix and oil in the tank it needs to be one or the other.
Old 04-16-2012, 10:32 AM
Member #25326
Thanks Bait what is the normal psi to run manual says 115 ppl on here say 90+
Old 04-16-2012, 10:42 AM
Bait's Avatar
Member #8552
mine had 90 cold and 80 warm and i was getting the blow back through the carb and it wouldnt start when warm. My piston was fine and i just replaced the rings and now im at 130. So you can see what 10lbs will do these bikes. The way the engine is design any leakage and your screwed.
Old 04-16-2012, 11:49 AM
Member #25326
just took jug off and appears like it been resleeved* unless these engines have steel "sleeves" in them already.Also has gas in bottom of motor. I posted pic under my photo alubum. couldn't figure how to insert them into message
Old 04-16-2012, 12:26 PM
Bait's Avatar
Member #8552
just took jug off and appears like it been resleeved* unless these engines have steel "sleeves" in them already. I posted pic under my photo alubum. couldn't figure how to insert them into message
i cant see a sleeve in the picture but then again im on my phone. Is the piston standard size>? it should have marking on it.
Old 04-16-2012, 12:47 PM
Member #25326
markings on piston is 0.25 50-30004p i was just tryin to look it up and nada
Old 04-16-2012, 01:00 PM
Bait's Avatar
Member #8552
well thats a oversized piston for sure
Old 04-16-2012, 01:16 PM
Member #25326
i thought so also just by the # i was figuring by atleast by .25mm
Old 04-16-2012, 01:17 PM
Member #25326
so this is what i'm figuring new jug piston & rings should fix this
02 trailblazer having trouble starting and backfires
03 polaris trail blazer starting problems
03 polaris trailblazer 400 turning over but not starting
04 polaris trailblazer gas tank
05 trail blazer ignition problems
oil tank location polaris trailblazer
polaris 400 trailblazer problems
polaris atv blow back into gas tank
polaris atv low power blowback at intake#gsc.tab
polaris trailblazer 400 ignition problem
polaris trailblazer starting problems
polaris trailblazer timing
starting problems with polaris trailblazer
troubles starting polaris trail
Starting problems iggys6 ATV Repair and Maintenance 3 06-07-2012 09:18 PM
Starting problems deerhunterbk ATV Repair and Maintenance 2 12-23-2011 10:30 AM
05 trailblazer starting problems elltrain89 ATV Repair and Maintenance 3 04-23-2011 05:45 AM
problems starting mattvanetten ATV Repair and Maintenance 3 03-26-2011 11:48 AM
500 efi starting problems allenpace ATV Repair and Maintenance 5 08-25-2009 04:40 PM
