Old 02-07-2010, 02:35 PM
1enick72's Avatar
Member #3027
02 trailblazer automatic performance
I just got a 2002 Trailblazer 250. I am new to polaris ATVs and wonder about the primary and secondary clutches. I grew up with snowmobiles and was thinking that the secondary clutch had 2 stages that felt like a shift point once you picked up some speed. Is this the case with the trail blazer?
Old 02-07-2010, 02:47 PM
no, the blazer has a CVT, so the ther is no "shift point" it just the way the primary and secondary move that is constantly chaging the belt ratio, but it will be smooth the whole time. they change based off of wheel speed and engine RPM
Old 02-07-2010, 07:49 PM
1enick72's Avatar
Member #3027
Thanks blueline. After inspecting the machine over I noticed some JB Weld looking stuff on the trans by the sprocket, looks like the normal chain came off and cracked the case. In getting another transmission do I have to get one for a trailblazer or will one from a scrambler 2x4 or something else work?
I would rather just get another trans than to buy a case half, tear in down and found the last person ran it low on oil for a length of time and messed up the rest of the insides.
Old 02-07-2010, 09:05 PM
if you are just looking to swap gearcase for gearcase, any of the following machines will work as a donor for you
2000 SCRAMBLER 2X4
2002 SCRAMBLER 400 2X4
2001 SCRAMBLER 400 2X4
1999 SPORT 400
2005 TRAIL BLAZER
2004 TRAIL BLAZER
2000 TRAIL BLAZER
2001 TRAIL BLAZER
2002 TRAIL BLAZER
2003 TRAIL BLAZER 250
1999 TRAIL BLAZER 250
2003 TRAIL BLAZER 400
2002 TRAIL BLAZER FREEDOM
02 polaris trailblazer 250 transmission
1999 polaris trailblazer atv automatic oil type
2002 polaris trailblazer 250
2002 polaris trailblazer 250 oil
2002 polaris trailblazer 250 transmission oil type
2003 polaris trailblazer 250 how to check the transmission fluid
2003 polaris trailblazer 250 transmission fluid
2003 polaris trailblazer 250 transmission fluid change
2003 polaris trailblazer transmission fluid
2004 polaris 250 trailblazer gear case oil
chain came off of my 2004 polaris trailblazer cracked the transmissin?
how to change a 03 polaris trailblazer transmission
how to change the transmission fluid in a 2003 polaris trailblazer 250
how to replace chain on 03 polaris trailblazer 250
polaris 250 trailblazer automatic
polaris trail blazer 400 oil type
polaris trailblazer 250 gear oil
polaris trailblazer 250 transmission oil change
polaris trailblazer gear oil
polaris trailblazer performance
