02-18-2010, 04:14 PM
Member #3249
rev limiter problem
hi i have a 87 trailboss 250. just got it running and seems like it is hitting the rev limiter way too early in forward and reverse. if you push the reverse override button when it is in reverse ....it hauls . i am kinda at a standstill. any help would be appreciated. thanks in advance
02-22-2010, 04:24 PM
Member #3249
cmon guys nobody has anything???
02-22-2010, 05:50 PM
i cant remember on your older machine if you have a throttle safety switch...located on the throttle cable itself. if that had too much slack in the adjustment, that could certainly cause these issues.
could also possibly be a faulty ECU
04-27-2010, 08:56 PM
Member #4579
Hi Mike,
Did you ever figure out what was wrong with you trailboss. My 87 is doing the same thing I think. Revs up about half way then seems to pulsate back and forth from trying to go to not trying to go. Since I am holding the throttle open trying to get it to go faster but the rpms won't go up, it does start to smoke a little from being too rich or kinda flooding. Idles perfectly. Lower rpms are smooth and perfect. But try to go over 10mph and it seems like a rev limiter is keeping it from going. Can't figure it out. Any help would be appreciated. Thanks so much.
10-06-2010, 09:48 AM
Member #7838
Did either of you ever figure out your rev limiter problem. I just bought a 87 trail boss that needed some work done. I got it running but i'm having the same problem, it runs good till about 1/3 throttle then it hits the rev limiter. The over ride switch was broke when i bought it so i took it off and tried running it with the wires apart then i twisted them together neither seemed to help.
10-06-2010, 10:06 AM
Member #4579
Turned out not to be rev limiter. Had an air leak. The intake was cracked and sucking air through at higher rpms causing the effect of a rev limiter. The intake is the short, hard rubber tube that attatches the carb to the cylinder head. Make sure it is not cracked and bolts holding it to cylinder are not loose. Runs like new since I found the leak.
11-06-2010, 05:30 AM
Member #7294
Good job on finding your own problem, this will help others.
06-30-2011, 06:04 PM
Member #16420
my reverse lite stays on must push overide button to get it to perform what could this be
bypass rev limiter on polaris predator 50, bypass rev limiter polaris atv, how do i reset the rev limiter on a polaris 6 wheeler, polaris 250 trailblazer rev limiter, polaris 50 rev limiter, polaris 50cc predator do they have a restart button, polaris 50cc predator rev limiter removal, polaris outlaw 50 rev limiter, polaris predator 50 limiter, polaris predator 50 rev limiter, polaris predator 50 revlimiter bypass, polaris predator rev limiter, polaris rev limiter, polaris rev limiter bypass, polaris rev limiter problem, polaris trail boss high speed problem, polaris trail boss rev limiter, polaris trailblazer override button, rev limiter polaris ranger, trail boss 250 rev limiter
