03-02-2010, 05:03 AM
Member #3420
2005 Trailblazer Reverse Issue
I picked up a 2005 Trailblazer 250 this past weekend. It is not in terrible condition but it has had a hard life. My question is in the transmission. It will go into Forward and Neutral but not Reverse. You can shift it into Reverse and it revs like it’s in reverse but does not move. There is no ticking or grinding in the trans when you shift into Reverse so I am hoping it is nothing major. Thanks for any help.
03-02-2010, 05:23 AM
i would start with checking the shift linkage from the gear selector to the tranny. make sure everything is snug and looks and feels adjusted right. possibly the adjustment is off enough that when you put it into reverse at the grear selector, the shift linkage is pushing the shift arm on the tranny far enough to engage reverse inside
03-02-2010, 05:52 AM
Member #3420
Thanks Blueline, I will have to check that. The odd thing is that the quad will not role when shifted into reverse almost like its in gear. The reverse indicater light even comes on.
03-03-2010, 05:26 AM
Member #3318
Seems like a damaged cog,
It could be its not engaged fully as the above poster suggested,
Tighten everything up, and or adjust the linkage, see how it fels after that,
03-03-2010, 05:41 AM
Member #3420
Damaged cog?
05 polaris trailblazer reverse, 05 trailblazer stuck in reverse, 2004 250 trailblazer will not go in reverse, 2005 polaris 250 reverse not working, 2005 trailblazer stuck in reverse, 250 trail blazer stuck in foward, blazer stuck in reverse, fix reverse on polaris 250, how to fix reverse on polaris trailblazer, how to fix the reverse on a trailblazer, my 2005 trailblazer is stuck in reverse, my reverse quit working polaris trailblazer, polaris 2005 trailblazer, polaris 250 trailblazer will not go in reverse, stuck in reverse trail blazer, trailblazer gear stuck in reverse 2005, trailblazer indicator light stuck in reverse, trailblazer stuck in reverse, trailblazor reverse quad, transmission stock on reverse trailblazer 2005
