Old 03-07-2010, 03:39 PM
Greg G's Avatar
Member #2185
broke the shift linkage rod
I have a 2001 325 Expedition, and broke the shifter rod between the transmission and the shifter pedal linkage.
Is there and easy fix, or does the transmission have to come out to change the rod?
thanks
2000 expedition shifter linkage broken
2000 polaris 425 shifter shaft
2000 polaris xpedition 425 schematic
2000 polaris xpedition how to fix shift shaft
425 polaris expedition shift rod
how do i install a new shifter arm on a 2000 polaris 425 expedition
how to change out a a shift shaft 2000 polaris expedition
how to change the shifter on a polaris xpedition 425 quad
how to fix shift linkage expedition
how to fix shift shaft on a polaris
polaris 425 how to replace shift rod
polaris expedition gear shift assembly
polaris expedition schematic
polaris shift linkage
polaris shifting rod
polaris xpedition 325 shifter stripped
replace shifter shaft 2000 expedition atv
shifter on polaris trailblazer broke
what is the shifter on a polaris expedtion 425 called
850 XP EPS broke axle!! mudbug_dw Polaris XP 16 05-20-2012 09:22 PM
won't shift into 4x4 jboc Polaris Sportsman 12 02-01-2011 09:55 PM
clutch problem 95 sportsman 400 broke? GArider ATV Repair and Maintenance 5 01-07-2010 01:30 AM
shit linkage boot radtad767 ATV Repair and Maintenance 3 11-17-2009 05:08 PM
Speedometer broke, 4WD DOES WORK!? lbm33 ATV Repair and Maintenance 2 10-14-2009 08:15 AM
