Old 03-23-2010, 09:02 AM
racinmandan's Avatar
Member #3341
super tight carrier nuts
gotta change my broken carrier on a 2000 trailblazer 250. the jam nuts are super tight. any tips on how to get them lose without doing damage?
Old 03-23-2010, 03:26 PM
redneck2725's Avatar
Member #3177
I'm sorry to hear you have tight nuts. Ok, seriously now, PB blaster or heat. Those are the 2 best ways to loosen anything
07 Polaris Predator 500
Yoshimura RS3 slip-on
ITP Holeshot HDs
Powermadd handguards
Shockwears shock covers
PRM radiator scoops
Amsoil oil w/ K&N filter
Engine Ice coolant
ODI Rogue Grips
Old 03-23-2010, 05:23 PM
Member #3341
thanks redneck. working as a service and body shop manager in a ford dealer, i buy the boys all the pb and laser (oxy/acet torches) they need. it's our most popular line of offense against "tight nuts"...lol. but before i do that, i just wondered if somebody knew a trick other than that. a friend was trying to get it apart at his place and broke a pipe wrench on it. i threw the whole thing in my truck and will take it to the shop this week and get it apart by hook or crook. if anybody did this job before and knows a trick to it, please drop a reply.
Old 03-23-2010, 08:53 PM
plowboy's Avatar
Member #3277
I use a air chisel with a blunt bit to break the outside nut loose.
It is better to remain silent and appear ignorant than to speak and remove all doubt
Old 01-02-2011, 07:14 PM
2strokertrlboss's Avatar
Member #10224
wow ....get out the torch and blast it for about 10 seconds......they will come right off......mechanics 101
atv lug nuts
how to get tight nuts loose
how to loosen super tight lug nuts
how to lose a tigth nut
how to losing a tight nut
odi rogue polaris sportsman
racinmandan
Super ATV Heavy Duty Axles Super ATV Super ATV 9 04-21-2011 01:44 AM
tight steering sportsman500 Polaris Sportsman 5 03-27-2011 01:37 PM
shatterd rim, stripped lug nuts, tailgateing, and $$$$$ in 3days chuckraduenz ATV Repair and Maintenance 9 03-21-2010 01:42 PM
Brakes not staying tight l-rod Polaris Sportsman 2 06-16-2009 09:56 PM
Super ATV is a Supporting Vendor! 4Nines Super ATV 5 06-16-2009 06:40 AM
