Old 04-11-2010, 03:11 PM
Stevehi's Avatar
Member #4236
Compression
Hi
I'm new to the board and have a question on trailbalzer 250 compression.
I did a check and it's at 110 pounds. Is this ok or should i be looking for more. I put squirt of oil in the cylinder and got 115 pounds pressure.
Old 04-11-2010, 04:38 PM
that sounds pretty good. usually, over 100 is good on these machines. but i dont know what it is supposed to have exactly either. if you would have said something like 90, then that would have set off a red flag
Old 04-17-2010, 02:19 PM
galaxiedan's Avatar
Member #486
Is it not running? Why did you have to do a compression check?
2005 Predator 500:
K&N filter on carb, jetted, pipe, nerfs, etc
1996 Trailblazer 250:
rebuilt trans
1993 polaris trailblazer compression test
2001 polaris compression release
2001 polaris trailblazer compression chart
2006 polaris predator 500 compresse
250 trailblazer compression
97 polaris 400l 2 stroke automatic compression release
compression on a 2001 polaris trailblazer
compression polaris trailblazer
compression ratio of 2003 polaris predator 500
how much compression should a polaris ranger have
polaris 250 compression
polaris 250 compression check
polaris 250 compression specs
polaris compression specs
polaris trailblazer 250 compression
polaris trailblazer 250 compression specs
predator 500 compression test
predator 90 compressiom
predator 90 compression check
Compression relief on 2006 Sportsman 500 HO Big Archery Nut ATV Repair and Maintenance 12 03-26-2011 08:36 PM
97 Xplorer compression? treedodger ATV Repair and Maintenance 2 01-11-2010 07:48 AM
Predator 90 Compression Spec? gmiller0737 ATV Repair and Maintenance 0 12-14-2009 01:42 PM
Compression release valve sticking on exhaust cam shaft. WLong2485 ATV Repair and Maintenance 0 11-25-2009 04:48 PM
No compression chewy1010 ATV Repair and Maintenance 1 10-29-2009 08:52 AM
