Old 04-18-2010, 05:38 PM
3 Polaris Atvs's Avatar
Member #1102
Trailblazer wont idle and bogs
Going riding next week end and taking some buddys with. My one friend brought over his trail boss over (with 00 Trailblazer engine). He took carb apart 2 times and I did once. It was full on crud the first time and we also drained the tank. It wont run with choke off. Quad has been sitting for 3 or four years. I tryed spraying for vacuum leaks and found none. I just cleaned the carb on my Trail blazer and this looked the same. What am I missing?
Old 04-19-2010, 07:01 PM
proff's Avatar
Member #4309
when you took the carb apart did you remove the pilot jet and spray it with carb cleaner. Then shoot it with compressed air if you can.
Old 04-19-2010, 07:19 PM
Member #1102
Yep, going to swap my good running carb for this one tomorrow. Will a carb off 400 interchange?
01 polaris trailblazer bogs after idle
05 blazer wont idle
1996 polaris express bogs at full throttle
1996 polaris trail boss bogging
1996 polaris trailblazer 250 carburetor float setting
2001 blazer wont idle
2001 polaris trailblazer runs poor
2004 trailblazer wont idle
96 polaris trailblazer bogging on full throttle
96+trailboss+wont idle
adjust choke pilot 250 trail boss
how to trailblazer vacuum leak
polaris 2004 trail boss rough idle
polaris trail boss will only run with choke on 1996
polaris trailblazer 250 carburetor diagram
polaris trailblazer 250 idle
polaris trailblazer 400 wont idle
polaris trailblazer wont idle
trailblazer 250 will not idle
trailblazer bogs out when full throttle
2000 Trailblazer rough idle/sputtering psavas Polaris Trail Blazer 3 04-17-2010 03:19 PM
Sportsman 500 wont idle Aggiemike Polaris Sportsman 5 04-10-2010 04:00 PM
04 predator wont idle,any advice wil help T PAYNE Polaris Predator 1 03-16-2010 09:42 AM
ok lets see who is god here, trailboss wont idle or comeup to ful throttle rekd65 ATV Repair and Maintenance 4 10-07-2009 08:31 AM
polaris xplorer 400 wont idle bracbrown1 Polaris Sportsman 2 06-07-2009 05:06 AM
