05-03-2010, 06:10 PM
Member #4203
00 Trail Blazer Steering
I have a 00 Blazer 250 and the steering seems very tight and rough. When i compare it to my 03 Trail Boss 330 it is tight almost to the point it sucks to ride it on trails with out going super slow, when I ride my Trail Boss I can turn it with out a problem and it seems super easy to turn compared to the Trail Blazer. I know that these two are almost the same thing and I was wondering if anyone out there has ANY ideas to help the steering become more comfortable.
Chris
05-03-2010, 07:46 PM
Member #1102
I would start by jacking front up and check for any thing that may be tight. If it is not tight then check for toe in being correct. I rode my buddies 94 trailboss around the yard while it did seam to turn easier than my trailblazer it felt twitchy and tippy? Maybe what you have is normal.
1998 Scrambler 500 HO 4x4
1995 Scrambler 400 4x4
2000 Trailblazer 250 2x4
Sportsman 90
1998 Sportsman 500 4x4
05-05-2010, 02:25 PM
Member #4665
have yah ever roller it or a previous owner .....i bent my steering stem when i rolled mine did somethign very similer ,it causes the top bushing to bind which makes it stiff to turn
05-07-2010, 07:03 PM
Member #4772
I just picked up my first atv and it is a 2003 Polaris TailBlazer 250. The steering on it is hairy. I can only open it up half throttle on pavement as it seems to take off left and right at the slightest touch of the handle bars. It seems ok on the trails, but crap is it touchy on the road. My brother in law has a 350 and it does not seem to have the same issue. I just replaced the one lower ball joint and everything else appears really tight. Maybe too tight ?? So maybe these TB-250's are like that, not sure. Pretty freaky when you appraoch 50 Km/h and then the bike decides to do a sharp left turn into on coming traffic !!
05-08-2010, 06:10 AM
Member #4665
check the alignment it sounds like the front wheels are toed out ? im unsure of the alignment specs but im sure another member will know !
05-08-2010, 01:44 PM
Member #1234
1/4" toe out is usually max. could try greasing the upper and lower bushings, but the weird feeling may most likely be from the narrower handlebars
2002 trail blazer 250 steering stem, 2003 trail boss steering stem bearing, blazer steering problems, front tire alignment on a polaris trailblazer, how to align a polaris trailblazer, how to align front wheels polaris trail boss, polaris 250 trailblazer steering problems, polaris 500 4x4 steering, polaris atv 250 trailblazer front alignment, polaris atv 250 wheel alignment, polaris atv toe issues, polaris scrambler steering alignment specs, polaris steering problems lower ball joint, polaris trailblazer 250 steering stem, polaris trailblazer alignment, polaris trailblazer alignment specs, polaris trailblazer steering stem, steering stem for 250 trail blazer, tire alignment measurements for a polaris trailblazer 250, why is my steering so tight on my polaris scrambler
