Old 05-11-2010, 12:52 PM
cwhitey's Avatar
Member #4203
Problems with the Recoil Starter
Are any of you having any problems with the recoil starter on either the Trail Boss or Trail Blazer? I had the battery die on my 00 Trail Blazer so I decided to just use the pull start, well it was fine for about 1-2 weeks and then on Friday I pulled it and the rope stayed in my hand. Well if I back up about a month... The battery died on my 03 Trail Boss so i did the same and well you guessed it the rope snapped in my hand the same way. Is this a common thing with these motors or.......... am I wrong to want to pull start my quad instead of using the electric starter...any ideas on a replacement rope to use or should i just not use the pull starter. Thanks for the inputs
Old 05-11-2010, 01:07 PM
josh's Avatar
Member #4417
sounds like maybe the rope was just getting old, I pull my 99 magnum and 00 scrambler pretty often and have never broke a rope yet, a lot of times water gets in the case and rots the rope, this may have been the case for yours.
Old 06-29-2010, 10:13 AM
befsman's Avatar
Member #5673
I just purchased a 95 blazer for a real good price. The only thing that is really wrong with it is that the recoil starter housing is gone. I wrap a piece of rope around the pulley and it cranks every time. My question is will the recoil starter from other years and motors bolt up to my 95 blazer. The OEM parts are really pricey and I would love to be able to salvage the piece from a wreck or something like that. Any advise would be humbley appreciated. Thanks.
Old 06-29-2010, 10:27 AM
josh's Avatar
Member #4417
contact tt425 on here, he would probably have one that would fit and is a great guy top deal with. to my knowledge most polarisis have the same side cover, so you should be good.
Old 06-29-2010, 11:17 AM
befsman's Avatar
Member #5673
Thanks Josh, I really appreciate it.
1998 polaris recoil issues
1998 polaris trail boss 250 how to recoil pull cord
1998 polaris trail boss recoil
2000 polaris trail boss recoil diagram
2000 polaris trailblazer 250 recoil repair
99 polaris 250 ropestart schematic
atv recoil problems
diagram of the pull start for a polaris trailblazer
hand recoil starter polaris trailblazer 400
how to disassemble polaris trailblazer recoil starter
how to replace pull rope for on a 2003 polaris trail blazer
polaris 250 trail boss recoil
polaris atv starter repair
polaris recoil diagram
polaris recoil starter repair
polaris trail boss recoil starter
polaris trail boss recoil starter info
recoil starter on a polaris
troubleshoot recoil starter
rebuilding a pull rope starter or recoil starter? booger68 ATV Repair and Maintenance 4 12-23-2011 03:13 PM
'09 Sportsman 400HO - Add recoil starter... 1of7627 ATV Repair and Maintenance 0 05-03-2010 10:19 AM
Recoil Starter, HELP!!! ctank01 ATV Repair and Maintenance 5 12-12-2009 07:08 AM
sawtooth 200 starter problems nickspolaris ATV General Discussion 2 08-02-2009 04:57 PM
starter problems 08 400 atv chris01 Polaris Sportsman 0 05-15-2009 07:02 PM
