Old 08-09-2010, 06:57 PM
lefty's Avatar
Member #6437
Wont stay running
Hello, I just picked up a used 96 Trail Blazer that runs great if you keep the throttle going. It wont idle at all though. It sounds like it is sucking too much air but I am not sure. The only way to get it strated is with half choke and then using the throttle as well. If you let up at all it winds down and dies.
I put in a new fuel filter,new plug and the value on the bottom of the tank was leaking so I replaced it as well. I also drained the tank and put in fresh gas. Topped off the transmission fulid and checked the air filter which looked like a K&N, redish purple in color.
Any help is greatly appreciated.
And if you know, how hard is it to take out the carb and clean it?
Old 08-09-2010, 08:03 PM
Old 08-10-2010, 08:20 AM
lefty's Avatar
Member #6437
I figured out the problem. The intake gasket is torn so I have it at a shop being fixed.
Old 09-11-2010, 07:36 AM
psavas's Avatar
Member #3485
The carb is really easy to take off and clean as long as you understand the basic workings of a carb. I clean mine regularly and leave all the hoses connected and clean the parts serperate. If your bike has been sitting for a while I would recommend taking it off the engine and drain the bottom plug and take off the reservoir and clean the jet/floats/and needle.
2000 Trail Blazer 250
1996 Trail Blazer 250 Project Rebuild - Complete!
Old 09-11-2010, 10:11 AM
lefty's Avatar
Member #6437
After taking it in and having them clean the carb and putting in Hi altitude jets and the intake gasket the bike runs great now.
Old 09-11-2010, 05:41 PM
psavas's Avatar
Member #3485
Sweet man! Cheers! Happy Riding
2000 blazer wont stay running
2009 polaris 90 four wheeler will not stay running
250 trailblazer wont stay running
4 wheeler wont idle so it wont stay running
96 250 polaris trailblazer 4 wheeler carburetor
96 balzer will not stay running
atv wont stay running
four wheeler wont run without battery
new polaris atv wont stay running
polaris atv will not stay running
polaris diesel atv wont stay running
polaris razor wont stay running
polaris trailblazer 250 wont stay running
polaris trailblazer wont stay running
spolaris 250 trailblazer carb adjustments
trailblazer wont keep running
why wont a polaris sportsman battery stay charged
will a 2000 polaris trailblazer 250 fourwheeler run without a battery
will a polaris four wheller run without battery
will polaris four wheeler stay running without battery
06 Polaris Sportsman 800 EFI quits running after an hour of running perfectly buckshotmudder ATV Repair and Maintenance 1 03-29-2010 07:23 PM
04 600 Wouldn't Stay Running in the Cold pasty64 Polaris Sportsman 4 01-05-2010 12:55 PM
05 sportsman battery wont stay charged mikgro ATV Repair and Maintenance 7 11-25-2009 03:18 PM
Xplorer wont stay running after 15minutes cornerstonepits ATV Repair and Maintenance 1 07-12-2009 05:08 AM
wont charge battery while running?? nitrous347 ATV Repair and Maintenance 6 06-20-2009 07:39 PM
