Old 08-22-2010, 04:23 PM
denverdale's Avatar
Member #1667
Belt jumps off clutch.HELP!!!
I Have a 93 trailboss 350L 4X4. Does the secondary clutch move in and out? When i Push in on the primary clutch the pulleys don't line up. I looked at an exploded view and the secondary clutch has a spring behind it but the driven clutch on mine doesn't move.
Old 08-22-2010, 06:27 PM
4getful2's Avatar
Member #1234
the rear clutch has a spring and helix built on the inside of the two assemblies. i would look at the spring and weights of the front clutch ,also check for a broken motor mount
Old 08-23-2010, 03:20 PM
denverdale's Avatar
Member #1667
Motor mount wins!!! This time. Now to see if I can find one locally.Thanks
Old 09-02-2010, 03:37 PM
denverdale's Avatar
Member #1667
That did it. Now I have to figure out witch hose hooks to the overflow nipple on the bottom of the carb. It leaks.
Old 09-03-2010, 04:14 AM
Manaen's Avatar
Member #6699
If it's overflowing you need to check your float level, needle, and seat inside the carb. It should not be leaking under normal operation when sitting on level ground. It may just need to be cleaned. Many times the needle gets dirty and jsut doesnt seal properly so it just continues to leak. It can be dangerous depending how it is sitting because the gas can run into the engine instead of the over flow. I've seen an engine almost completely full of gas. When the user tried to start it the motor hydraulic-ed. Anyway clean/check your carb before fixing the hose.
BTW.. The hose tee's with another overflow on the side of the carb and then runs into a one way valve to keep water out of the carb.
05 polaris trail blazer motor mount clutch problem
350 polaris trail boss clutch
93 polaris 350l overheats
93 polaris trail boss 350 belt replacement
93 polaris trail boss primary drive clutch
broken motor mount on polaris trailboss
check polaris clutch belt
how to adjust belt on polaris trail boss
how to take the belt drive off the a polaris engine
how to tighten a polaris trailblazer belt
polaris 250 belt replacement
polaris 250 trailblazer drive belt picture of replacement
polaris 330 trail boss belt replacement
polaris 350l motor mount replacement
polaris atv 350 trail boss how to change rear moter mount
polaris trailblazer 250 motor mount help
polaris trailblazer motor mounts
polaris trailboss 350 motor mount
primary clutch removal polaris trail boss
trail boss 350 clutch
ugh, this clutch/belt 4chevys4me ATV Repair and Maintenance 10 03-04-2011 04:33 AM
2000 Clutch Belt Replacement emike10 Polaris Sportsman 7 02-23-2011 04:17 AM
2009 Sportsman 400 HO jumps on take-off JoeG Polaris Sportsman 1 07-11-2010 09:06 AM
Clutch or Belt ???? Any Help Rip it up ATV Repair and Maintenance 1 05-21-2010 03:51 AM
clutch belt bomberboat ATV Repair and Maintenance 1 01-17-2010 12:42 PM
