09-01-2010, 10:14 AM
Member #6874
No start, 01 250 trailblazer
I feel like this is a common problem..
I got a swamped ride and tring to wake it up. 1st we
Replaced coil under flywheel and got good spark, carb is clean but after cranking on this bike for most of the day, just a few pops.
After reading it is common to have low compression and mine was soaked and left wet for months..we've drained the crankcase, cleaned the exhaust out..Nada... just an oily spark plug..
What should a good pressure be for the compression?
Does this have reeds or ports that require service?
Could spark timing be the issue?
Thanks in advance, Dag-n-Jr
09-01-2010, 10:39 AM
are you getting fuel with the oil?
compression should be 90+
09-01-2010, 11:54 AM
Member #6874
no start
Engine feels like it has enough pressure but guage reads 75psi. Plug has mostly oil and it appears not to draw fuel thru carb as strong as I would think. Thats why I was thinking reed valves.
09-01-2010, 05:55 PM
Member #6699
75 is very low PSI
There are no reed valves in these engines. They work strictly off of port timing. You may also have bad main seals if it was sitting for a while. Also I suspect the cylinder is rusty and pitted along with the crank and main bearings. If water remains in an engine for a long time it will rust very quickly. I would pull the head and check the cylinder it's possible you can get by with a hone and new rings. I would also disconnect all the wiring connections and clean them and then apply dielectric grease to all the connections to eliminate any oxidation/corrosion problems.
For future reference if this happens again you should pull the drain plug on the bottom of the crankcase and crank the engine. Then get it running to full running temps to clear all the water out. Spark problems can almost always be repaired by cleaning up the wiring with WD40 (as a quick fix) and dielectric grease for a longer term fix/preventative maintenance.
09-11-2010, 07:17 AM
Member #3485
I don't know if this helps but I just rebuilt a 1996 TB and I had a problem with it getting gas an oily black plug. I took apart/rebuilt/cleaned the whole carb and made sure my vent lines were not clogged. I than put everything back together and still couldn't get it to fire, mind you the guy I bought it from said it had not ran for over 6 years). I had great compression, spark everything could not figure out for the life of me what the heck the problem was. I decided to put the airbox back on the carb, sure as sh!t next crank it fired up the and has not stopped running to this day! I know about air/fuel ratios but I think these polaris two strokes are extremely tempremental when it comes to the "little things."
Just my $.02
2000 Trail Blazer 250
1996 Trail Blazer 250 Project Rebuild - Complete!
01 polaris trailblazer 250 wont start, 1996 polaris trailblazer 250 not getting any fuel, 1996 polaris trailblazer 250 not gettn any fuel, 2001 polaris 250 engine overhaul, 250 trailblazer no start, compression readings, 2000 polaris 250 trailblazer, does a 2001 polaris trailblazer 250 have any oils in the crank case, drainplug for the starter on a polaris trailblazer, how much compression does a 250 trail blazer polaris has to have to run, how to replace reed in 96 polaris 250, my 2000 polaris trailblazer 250 lack of power, polaris 250 trailblazer reed valce, polaris 250 trailblazer reeds, polaris trailblazer 250 compression, polaris trailblazer 250 engine timing, polaris trailblazer 250 how to start, polaris trailblazer 250 reeds, polaris trailblazer timing, polaris trailblazer will not start, why did my 96 polaris 250 trailblazer spark
