Old 09-07-2010, 12:06 AM
CAtrailblazer's Avatar
Member #7054
Oil Injection Question
I just got my gf a 02 TB. We went riding all weekend. My question is I filled up the oil res. to the top and we rode for about 3 hours for two days. Used about 6 galls of gas. I checked the oil res at the end of the trip and it looks like very little oil was used. Is this normal for these machines? Also where does the oil overflow tube go. When I took the front cover off it was just twisted around some of the headlight wires.
Thanx for any help given.
Old 09-07-2010, 01:07 AM
4getful2's Avatar
Member #1234
polaris oil injection figures out to about 50 to 1,so yes it will not use much.
Old 09-07-2010, 04:18 AM
Manaen's Avatar
Member #6699
Plus at idle the figures are even leaner like 70:1.
Just take a gander at your oil pump and make sure the cable is adjusted properly. There are marks on the arm that should be aligned when the throttle is released (sitting static) some times the cable can stretch over time and needs to be re-adjusted. If you do adjust it make sure you also adjust your carburetor free play as well. You should do your oil pump first and then the carb.
Old 09-07-2010, 05:02 AM
Old 09-07-2010, 03:38 PM
Member #7054
Thanx for the help guys. I guess I will just keep an eye on it.
Old 10-11-2010, 12:52 PM
whitejc4's Avatar
Member #6757
4getful2, I am pretty new to atvs but I recently swithed my 04 trailblazer from injection to premix. I am running around 32:1. I did not notice any smoke or difference in performance. Am I running to rich? Should I mix at 50:1 like the injection? Thanks
Old 10-11-2010, 01:15 PM
CAtrailblazer, sounds pretty normal. They dont use much oil.
Whitejc4, you certainly are not going to hurt anything running 32:1 other then maybe fouling plugs quicker then normal and having to buy oil more often. 32:1 is a safe ratio for 2-strokes in general. It seems polaris does run leaner, and my guess is a 45:1 or 50:1 but im not for sure.
I tend to like to play it safe, so my .02 is to stick with the 32:1. Oil is cheaper to buy then an engine rebuild. Unless someone with a 250 trailblazer can confirm that they run 50:1 with no problems.
Old 10-12-2010, 04:45 AM
whitejc4's Avatar
Member #6757
thank you blueline15 for the response. Are there any 250 trailblazer riders who can chime in? Thanks
Old 10-24-2010, 12:52 PM
Manaen's Avatar
Member #6699
You can actually hurt your engine if you run too much oil. The oil can gum up the rings on the piston and cause them to stick which will kill your compression and send you down the rebuild express. Also keep in mind the more oil you have mixed in the gas the less gas there is in the carb, which will actually cause the engine to run too lean. Keep in mind these carbs are all setup to run with no oil in the gas. You need to adjust the carb properly for your leaner mixture. This will cause it to use even more oil.
Just some food for thought before you all disconnect your oil injection and and start premixing your gas.
Old 11-29-2010, 09:37 PM
onesdman's Avatar
Member #5657
No one answered the question about the oil tank upper line(Over Flow ?) mine is also disconected and I would like to know where it goes
adjust oil injection on polaris 400
how can i tell if the oil injector is working on a polaris atv
how do i know what injector oil do i need for my atv
how do you know where to properly adjust the cable on an 03 polaris 800 oil injector
how does a polaris oiler work
how does the oil injection work on a polaris
how to adjust oil injection on a polaris
how to do away with a polaris injection pump
moving oil pump 4 polaris 250
polaris 400 oil injection adjustment
polaris injection oil
polaris injector oil
polaris oil injection adjustment
polaris oil injection pump
polaris oil pump adjustment
polaris trailblazer 250 oil injection ratio
polaris trailblazer oil injecton
polaris trailblazer oil pump
polaris trailblazer where does oil inject
oil injection delete,do you have to rejet? 425whpsti Polaris Scrambler 4 11-27-2011 09:57 PM
Oil injection Spring Return x omerta x ATV Repair and Maintenance 0 07-12-2010 03:38 AM
Oil injection Spring Return x omerta x Polaris Scrambler 0 07-12-2010 03:37 AM
how to belled/check oil injection bigopie1 ATV Repair and Maintenance 5 10-28-2009 02:37 PM
oil injection pump frony83 ATV Repair and Maintenance 2 06-22-2009 05:39 PM
