Old 09-26-2010, 12:33 PM
Land Gal's Avatar
Member #7620
Question Please Help 1998 Trail Blazer Questions.
I Just Got Free A Trail Blazer. Cowel Says 1998 Manufacture Date.
It Will Not Start.
There Was No Gas In It, No Oil In The Front Oil TAnk, And No Key.
I Did Bypass The Key So It Should Start By The Pull Start Rope. But It Will Not.
I Just Wanted To See It Run For A Min Or Two Before Ordering A New Key And Switch.
What Oil Do I Use In The Oil TAnk?
What Type GAs Runs Best 87,93,98 Or Non Ethinal?
Also Is There Any Other Specal Things To Do To Get It Running As Well As Keep It Running?
Thank you.
Old 09-26-2010, 12:56 PM
how long has it not been running for?
please, do not pull start it until you get oil in that tank, and honestly, you should bleed it all the way to the oil pump. you could have siezed that motor in only a few seconds had it started with no oil in the tank. get a synethic 2-stroke oil. doesnt need to be fancy.
87 octane is fine, a non-ethanol is best.
you are probably going to have to clean the carb, replaces the jets, probably replace the needle valve, inspect the needle, and inspect the floats. The tank will also probably need to be cleaned out.
my suggestion is to, in this order.
get 2-stroke oil in the tank and bleed it through to the pump.
fill tank with gas, add 2-stroke oil to gas somewhere around a 40:1 or 45:1 ratio....(at this point, we would rather have too much oil and foul a plug then sieze the top end. especially since we dont know if the oil pump is still working. incase its not, at least you still have oil in the fuel. it will be clear by how much smoke you get if the oil pump is working or not)
take airbox lid off
okay now, i recommend getting a buddy and a bottle of brake cleaner, contact cleaner, starter fluid, or ether. before pull starting, make sure the quad is in neutral, and set the parking brake.
give it two or three pushes on the throttle, wide open and back. there is an accelerator pump that squirts a little bit of fuel everytime you open the throttle up, too many pushes on the throttle, you will flood it.
have a buddy spray a shot of (1 second) brake cleaner ect. into the air filter. as soon as he stops spraying, start pulling.
if it wont at least fire up doing that, you are going to have to start tearing it apart.
good luck
Old 09-26-2010, 01:11 PM
johnnyjaws's Avatar
Member #6548
...................welcome...................
2006 polaris 500 ho efi E.B.S. sportsmen k&n air filter . Genesis performance module . Hand gards . Back work lights .Front & back bumpers. 2500lbs warn polaris winch. A-arm covers front & back .Front & back rack extenders- Mossy oak soft bags & Rear passanger foot rests .Big wes cargo box .and a 60" polaris plow and a polaris gun side scabberd with 800 miles. Camo water grapics on the hand gards ,speedo mount, front plate,and shifter knob & gas cap- rear storage lid. 3 way head lite mod. Swamp lite 27s on itp ss 212 machined rims 12in. tall clear polaris lock & go wind sheild
Old 09-26-2010, 02:33 PM
1998 bravada, gas in oil tank
1998 polaris trail boss 250 flooding problem
1998 polaris trail boss 250 oil type
1998 polaris trailblazer
1998trail blazer
2 stroke 98 polaris trailblazer
best oil to use for a 98 blazer
how do you replace starter on 1998 polaris trailblazer 250
how to bypass override on 98 polaris trailblazer
how to change 1998 polaris trail boss rear brake
how to purge a polaris trailblazer oil pump
how to replace rear brakes 1998 polaris trailblazer
is a polaris trail blazers starter run in oil?
polaris atv/gas/oil mixture/1998 trail bolazer
polaris trail blazer serial number
polaris trailblazer 250 serial number
polaris trailblazer oil pump bypass
were can i see the seriel number of a polaris trailblazer 250cc
what kind of oil do u put in 1998 bravada
what kind of oil should i use for a 98 blazer?
250 trail blazer oil change metal man ATV Repair and Maintenance 7 01-30-2012 08:32 AM
00 Trail Blazer Steering cwhitey Polaris Trail Blazer 5 05-08-2010 01:44 PM
01 Trail Blazer Chain cwhitey Polaris Trail Blazer 4 04-17-2010 02:18 PM
Trail Blazer Info townercow Polaris Trail Blazer 7 12-12-2009 03:28 PM
trail blazer help goldnut ATV New Members 3 10-20-2009 03:28 PM
