10-20-2010, 07:12 AM
Member #8368
2010 Trailblazer
Hi all, I'm totally new here, and i just have a few questions. I have a 2010 Trailblazer 330 and would like to get alot more performance out of it, I've found a few parts online but i'm wondering if there is any way to get rid of the rev limiter? Is there an aftermarket CDI or anything like that? Any help would be appreciated, and also if you could post what you've done to your 330. THANKS.
10-20-2010, 08:57 AM
10-20-2010, 10:42 AM
Member #330
howdy
mid-ga. dirt dobbers
see ya on the trail or track
time ta scramble on
10-27-2010, 10:39 AM
Member #5749
depending how your warr. is these stealerships might try anything not to cover u.but a higher rate primary spring+setting your secondary spring from 1-1 position to 2-2 position adds rev,,,,,,,,,,,,,,welcome to the site, alot of knowledgeable people here.
11-28-2010, 09:11 PM
Member #8368
springs
can you elaborate a lil on how to put the secondary spring to 2-2 slot? Thanks
11-29-2010, 02:55 AM
Member #9037
.........and can it be done to an '05 Trail Boss as well?
11-29-2010, 07:21 AM
Member #5749
yeah there are holes in the non movable sheave + holes in the inner pully of the secondary. this preloads the tension of the secondary spring.adds more rev+it shifts quicker,sharper down shifts.stock is 1-1,if you turn the secondary over after you remove it and you see one end of the spring in a #2 hole than chances are someone already put it at 2-2 before you got it.you have to remove the clip and you will see the inner pully spins clockwise 1/4 turn.check your buttons that the sheave runs on is not too worn.put both end in the #2 position and turn the inner pully 1/4- turn then push down and put the clip back on,,,,,,,i have done many of these but 1st time is alittle difficult have help+the sheave only goes on one way so be careful not to buger it up(look for the space in the splines and mark it,very helpful)do this mod+get a epi red primary spring and will own an angry chainsaw.i also have other mods,,,,,,,,,,,,yes it will work on the 05 trailboss also.
12-10-2010, 04:14 PM
Member #9037
Thanks. After finding the video on youtube, it is very clear!!
02-01-2011, 02:53 AM
Member #2374
Revisit
bump^^^^. Anyone elso have anything to add
08-05-2011, 05:57 PM
Member #17304
Can this be done on a 2000 trailblazer? Saw a vid on YouTube of secondary assembly but no mention of multiple bolt holes. Maybe a vid link.
2009 trailblazer 330 performance kit, 2010 polaris trail blazer 330 discussion, 2010 polaris trailblazer 330 forum, aftermarket trailblazer 330, pipe for 2011 trailblazer 330, polaris trailblazer 2010, polaris trailblazer 330 modifications, polaris trailblazer 330 mods, polaris trailblazer 330 performance, polaris trailblazer 330 performance mods, trailblazer 330 mod, trailblazer 330 mods, trailblzer 2010
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Trailblazer
psavas |
ATV Wheels & Tires |
2 |
10-19-2010 04:21 PM |
06 Trailblazer help
BadBoy_GSXR1000 |
ATV Repair and Maintenance |
4 |
02-17-2010 04:47 AM |
Trailblazer??
doug rooney |
Polaris Trail Blazer |
1 |
01-16-2010 08:30 AM |
250 Trailblazer
Josephus |
ATV New Members |
2 |
12-09-2009 06:20 PM |
09 Trailblazer 330
twiqz |
8 |
07-09-2009 01:57 AM |
