Old 10-26-2010, 06:24 AM
Bait's Avatar
Member #8552
96 Trail Blazer chain information needed
First off this is my first post on this board, I have found a lot of information here and I appreciate the vast aray of knowledge here.
So I picked up this 96 Trail Blazer that needed lots of love, for sure she has seen better days but she is slowly coming around. One thing I noticed was excessive slack in the chain even when my 180 pound butt is sitting on it.
With that said what is the proper amount of tension this chain should have on it? Also it looks as if i just need to loosen the two axle retaining bolts and rotate the axle to apply the tension is that also correct?
Thanks in advance for help.
Old 10-26-2010, 06:42 AM
cwlongshot's Avatar
Wink
For adjustment yes. Loosen two bolts and rotate axle carrier.
As for proper amount, I like about an inch. Tad less for lighter rider tad more for a heavier one. Remember it tightens as it compresses. So if you get any air time you may not like the outcome if you go too tight.
Old 10-26-2010, 07:36 AM
Bait's Avatar
Member #8552
Thanks for the quick reply, right now it appears to very loose and is leaving wear marks on the top chain guide. I know that there will always be some wear there but it seems to be excessive. What would be a good sign of it being to loose other than it coming off the sprockets
Old 10-26-2010, 09:22 AM
cwlongshot's Avatar
Again, free play of more then a measured inch. Unless the riders weight is excessive would be too much.
Old 10-26-2010, 09:32 AM
Bait's Avatar
Member #8552
gotcha thanks for the information.
big boss polaris front chain adjustment
chain guide for polaris trailblazer
how do you tighten a chain on a 96 polaris trail blazer
how to tighten a polaris trailblazer 250 chain
how to tighten chain on 250 trailblazer
how to tighten chain on polaris trailblazer
how to tighten chain on trail blazer atv
how to tightin the chain on an 07 trail boss
polaris
polaris trail boss 250 chain too tight
polaris trail boss chain proper tension
polaris trailblazer 250 chain adjustment
polaris trailblazer 250 chain guide
polaris trailblazer chain adjustment
polaris trailblazer chain guide
tighten chain on a polaris 250
trail boss chain tight
trail boss proper chain tension
trailblazer aftermarket chain polaris
yughtening the chain on a polaris. trailblazer
250 trail blazer oil change metal man ATV Repair and Maintenance 7 01-30-2012 08:32 AM
TRail blazer....Vin #"s critch Polaris Trail Blazer 2 11-03-2010 03:08 AM
trail blazer swing arm 2slow Polaris Trail Blazer 1 07-24-2010 05:34 PM
01 Trail Blazer Chain cwhitey Polaris Trail Blazer 4 04-17-2010 02:18 PM
trail blazer help goldnut ATV New Members 3 10-20-2009 03:28 PM
