  #21 (permalink)
Old 04-19-2011, 12:02 PM
polarisTB's Avatar
Member #14062
so i checked out my carb and everything looks fine my bike will start up and when i shift into drive it stalls? and then I try to start it up again and won't what would cause this should I be cleaning out the carb with some spray or is this another issue some where else?
  #22 (permalink)
Old 04-21-2011, 06:42 PM
sfrasher's Avatar
Member #13967
Originally Posted by mds33031 View Post
Newbie.....
Silly question but I have searched and searched any even went to local dealer Team Power Sports and they had no clue either.
2001 TB 250... Where is the fuel filter and where can I get a OEM filter?
I appreciate any assistance.....
THANKS A MIL.....
I don't know if "TB" is Trail Boss or Trail Blazer, but my 2000 Trail Boss 325 has an inline fuel filter under the headlight. My fuel pump is there also. I also don't know if it was factory installed or after-market since I bought it used.
Spence
2001 Trail Boss 325, AA model, since April 2011
"I've been sane, and I've been crazy. Crazy is more fun!"
  #23 (permalink)
Old 05-11-2011, 06:11 AM
stephenmac's Avatar
Member #14945
hi guys im new to all this and may have a carb problem i have just bought a 2000 trailblazer
250 2- stroke sitting off the road for a year i have stripped down the carb and cleaned it all the way through also changed the plug cleaned the air filter set everything back up ,mixture idle etc it now starts and idles perfect but then i drive it its got a lack of power it sounds sweet but lacks top end any ideas would be great thanks
Tags
carb, carborator, issues, list
01 polaris 90 caberator adjustments
2001 polaris 90 spotsman runs then dies out
2001 polaris trail boss 325 diagram for fuel lines from carb
2001 polaris trail boss 325 fuel diagram
2001 polaris trailblazer 250 speed control
2002 polaris 90 carburetor
2002 polaris trailblazer 250 carburator problems
98' two stroke polaris quad common problems
carburator 02 polaris 90
carburetor diagram 250 trailblazer
polaris 90 carb adjustment
polaris 90 carb diagram
polaris 90 carb settings
polaris sportsman 90 carburetor adjustment schematic
polaris trailblazer carb adjustment
polaris trailblazer carb diagram
sportsman 90 carb adjustment
sportsman 90 starts yhen quits
were os the fuel circuit on a 2000 polaris trail blazer
what would cause gas to blow out of the carb on a polaris trail blazer?
'95 425 Magnum Carb issues JJAM234 ATV Repair and Maintenance 16 08-28-2011 10:15 AM
Sportsman 90, 2001, carb issues, etc.... RamThis Polaris Sportsman 10 06-30-2011 04:31 PM
Tech write ups for common repairs / issues / questions ? laterongc ATV Repair and Maintenance 4 01-23-2010 08:21 AM
99 Sportsman Carb Issues cveri Polaris Sportsman 2 09-29-2009 06:46 PM
Carb settings needed and Carb issues NolenGerke Polaris Trail Blazer 3 08-26-2009 03:30 PM
